Anyone found one of these before? Just found one two days ago. And yes the teeth were counted over and over I couldn't believe it. It was in a 88 tranny PL3 9000. Now I've seen PL3 9000's before but they are usually just JDM Si or SOHC ZC trannys this one is different but it also has never been apart till I got it. Was just going to steal the diff out of it for a customer's car and decided to use the final drive too combined with the Si gearing and the 5th out of the 88 tranny that was taller (Sorry don't remember the ratio) all the ratios were slightly taller than your usual DX/Si ratios. I can only assume Honda did this in JApan for 88 only and decided to go to the US spec DX/Si ratios later. Just thought it was an interesting find it's in a turbo CRX soi it should be quick even though the hp will not be very high. At least not till next summer then there is plans for more power of course.
or Europe trannys, CRX and Rovers...........
Rovers got the awesome ZC close ratio cable tranny with the 4.437 FD.......
Also a few D13 or D14 Civics got a 4.437 FD 92+......damnit!!!!!!
