1 - 12 of 12 Posts
00 civic
ok here is what i got a d15b8 block with a d16 oilpump and oil pan y7 head y7 intake. im running obd2b it is in a 00 sedan. the problem is it wont rev past 35000-4000 rpm no cel im just confused at this point any have any suggestions?
00 civic
yeah its like i hit a rev limiter but.......... you know when you hit a rev limiter it bounces this does not it is like total power loss.
have you checked the distributer, and all of the connections, mine started to do the same thing, i had a few bad connections.
00 civic
no i have not checked it i will when i get home and the rain stops.
racist-bigot-sexist-homophob
My DOHC ZC was doing something similar but it turned out to be the tune.
00 civic
yes i do have a crank positioning sensor that was the reason for putting the 1.6L oil pump a d15 motor does not have the mounting for the cps but i will check and see if it is bad or something.
1 - 12 of 12 Posts
