1 - 14 of 14 Posts
hello then name is matt
looking for u guys to help me out .. im building a d16z6 and looking for 350 to 400 hp at the tire
i have a lil $ to play with
sleving the block at this pt is out of the question
i have a xs power turbo kit with a greddy fmic a.r 50 trim shitty piping and 680 fuel injector clan injectors and a motorola 2.5 bar map
have no clue what the motor makes now its on 10 psi tuned by me on s300 withmy aem wideband and a lot of street tuning !
this is what i had in mind for the setup let me know what u think.. will be buying all this this week aslong as u guys thinks its a good build list
cp pistons 9:0:! comp
crower rods
bc stage 2 turbo cam
matching springs and retainers
mild port work by me
sendng stock crank to be cut and miced for bearings
oem hondata head gasket
going to a omni power 4 bar map
and maybe going to rc 750cc inj
what do u guys think i can make on a max of like 20 -22 ps for strip and 15 ish for street
thankls alot matt
I kept reading that those "50 trim ebays" are really 44trim. I can't remember what hp people pushed them too, but i think it was around 320ish. Why don't you go with some vitaras and no cams and buy a better manifold and turbo? If you have the shiny one that is.
Vitaras
crower rods
FJD I beams
Delta 252-272
Don't need
Good
Why?
OEM Honda will do fine or full rebuild kit from FJD
EBay will get you the best deal 125.00 shipped
Only thing I have additional to what I listed is a Edelbrock intake mani and precision 880's. I am making mid 300's with a shity ebay turbo which has blown seals at 20psi. Invest in a real turbo. Second hand or from Go-auto(best possible merchant out there)
Go the cheaper and proven route. You still have to think of catchcan setup and Dyno tune time. Street tuning is cool if you don't have another option but a Dyno tune with a real tuner is priceless.
DON'T cut the crank. Just mic it, do the math, and use OEM bearings.
im running a xs power turbo ar 50 cold side ar 63 hot and its sup to be 57 trim but they measure out to be 45 trim but at 11.5 psi on my stock a6 i made 220 whp and 201 ft lbs tq on turbo edit running 13.7s in the quarter bumped it up to 14 psi and now running 12.89s on both numbers i was on slicks.
if you have the money, hell yeah
crower rods
if you have the money hell yeah
nice cam
if you want to make use of the cam and rev above stock limit sure
will get the job done
why cut the crank?? has it spun a rod bearing?? just get a good used crank, get it micropolished, and your golden
hondata isnt oem, just get a felpro mls
get a gm 3 bar
who knows until its on the dyno
thankls alot matt
if you have money to spend, you can eliminate some of the things you have listed, and get a decent turbo/manifold
i just dont understand why you cheaped out on a turbo kit, and then get a s300.. but your somewhat on the right track
1 - 14 of 14 Posts
