1 - 13 of 13 Posts
Just wanted to know if anyone have used these injectors before?
Are they a good replacement for RC310?
I found some one ebay for $160 NEW
Accel 310cc Injector #153310
ACCEL 153310 - ACCEL Fuel Injectors - Overview - SummitRacing.com
Import Performance Parts - ACCEL Performance Plus Fuel Injectors
Also wanted to know if they are good for 160-170 HP.
i tried a few turbo calc and they all say 160hp needs 344cc injectors, but
also did a revise injector calc and came up with.
310cc 4 injectors .65 BSFC = 145 HP
440cc 4injectos .65 BSFC = 206 HP. That seems low since i hear people running 440 and making 300whp
310's are good to 200whp...you'll be fine...but why spend 160 when dsm's are 50-100
^ this.
And you know you can calculate the size of inj u need by raising the fuel press to effectivly make the 310 'bigger'
RC Fuel Injection
yea i know that but these are drop in no box needed (even tho i can wire up anything). Plus there new not 10years old :p
http://www.d-series.org/forums/general-tech/101532-fuel-injector-limitations.html
310 should be good for around 200HP
there's a person on here that is selling a set of those
if he chime in/ or someone let me know but i also wont have the money till next wk.
and thanx for the information on them working
^ this.
RC Fuel Injection
yea thats where i got the sizing but i just wanted to know what they would do without upping the fuel psi
if you have a set of 310cc inj's, rated at stock fuel pressure, raising the fuel press makes them flow more because the extra press is forcing more fuel threw in the same amount of opening time. The calc on there lets you figure out how much more.
i am using 310 injectors on my d15b t3 setup as a DD on 7 psi. they work perfectly fine! they can be used upto 10 psi with fuel pressure raised to 50-55.
1 - 13 of 13 Posts
