1 - 20 of 95 Posts
95 ex coupe
Jeep wrangler DD
3" is more than enough for what you're doing. Remember, if you ever decide to do exhaust, 4" isn't cheap, or easy to do
90 crx si/96 accord
One of the recent tuner mag's (super street, import TNR, or modified) did a. Very similiar test comparing 3 vs 3.5 exhaust on a supra The 3.5 netted over 30 horse on the 3.5 vs the 3. If ya got the room. Go big
95 ex coupe
got to remember thats not a civic. much larger motor and prob much bigger turbo.
and you didnt tell us how much power that supra was making.
94 Civic Hatch
knowing it being a supra is gonna suggest that they are making well over 600whp. there is a shop up here in maine that has a supra they use for drifting and they had it tuned down to 650whp for the track by my house. the thing is beast on bigger tracks he was telling me he runs about 800whp
dont know how true it is but it is deff a crazy ass supra
90 crx si/96 accord
February 2011 Modified mag. Pg74
3" exhaust baseline 527 whp @ 19 Psi
3.5 exhaust netted 567 whp peak gain of 66 whp @ 6000 rpm
3" @ 29 Psi = 699whp
3.5 @ 29 Psi = 740
In the article it noted that the turbo spooled 150-200 rpm's faster with the larger exhaust diameter because The extra half inch equals 36% increase of volume
turbo outlet size on the supra?? willing to bet the turbo outlet was already 3"..
outlet on most turbos a civic can mount, including the one the OP has, is only 2.5".... so a 3" DP is technically .5" bigger then it needs to be...
OP: keep in mind most places only keep 4" pipe for diesel trucks. which also means they will probably NOT have the right bends to make an exhaust for a little civic with ZERO room for it.
also its probably good to remember that 400+ whp has been made on 3" DP and exhausts (no cat), which is way way more then most street cars need. if your running a drag only car, just run it out the side with the 3" or out the hood with a little 4" pipe. either way, if your driving on the street, 3" is more then enough for that you can control on street tires.
97 honda coupe
lmk how that fits over the rear LCA... oh and past the shift linkage.. :wacko:
idiot. sometimes i just dont know about you.
lol, wasnt thinking about running it all the way back, just a downpipe and then out the side before the pass tire.. yknow.... sidepipe....
more weight. stay with 3. or just run open downpipe?
1 - 20 of 95 Posts
