1 - 10 of 10 Posts
hey people.
looking for a 3" sports cat or 2.5" at minimum for my D16Z6. im looking to import from the states as they are £230 over here and ive heard you can get them for $90 in the states.
so any brands or links would be really helpful.
cheers.
luke.
just for emmision reasons here in the UK.
atm the plan is to go from my 3" DP to a 3" CAT and then down to my 2.5" buddyclub system, im having the exhaust place fab up a straight through center section while they move the O2 bungs slightly.
will this work? http://www.procivic.com/pages-product_car_part_info/category-70_86/product-916/index.html
i could have the new straight through center section extended to the DP and this CAT welded into it.
well here is the issue. "high flow" cats are normally just resonators or weld ons that look like a cat. there are a few on the market that are actually catalytic converters. these are often listed with the cell count of the cat listed.
Well?
ill be using a magnaflow cat on my boosted setup, either that or like pat is sayin get one from a diesel truck like he did and use that
i jus found a UK dealer for the spun CAT, should come in at under £80.
does anyone know the diameter of the buddyclub pro spec center section?
1 - 10 of 10 Posts
