1 - 3 of 3 Posts
My Crix
search is your best friend.
1. It allows you to modify your cam timing in 1 degree incriments, up to 15 degrees and advanced and 15 degress retarded from tdc.
2. you should, but it depends on what lift and duration the lobes are and what rpm the motor will be seeing.
3. please restate, several questions can be assumed from this poorly written request.
Honda
:TU:
ecu tuning will not be required with installation of cam gear and cam, gut is HIHGLY reccommended
1 - 3 of 3 Posts
