Good day,
I built a high CR D16Z6 NA engine.
So it is leaking oil AGAIN, and I decided to clean it and put baby powder on it to see exactly where it is.
Note - the leak is between the top and bottom part of the solenoid, and the main expensive rubber gasket with mesh is replaced.
I am kinda sure I can solve Leak 1 unscrewing the solenoid top and polishing surfaces/adding sealant.
Note that I changed distributors O-ring seal to a Honda one. And note that the distributor itself is dry.
Maybe leak 2 could be from a sensor bolt? But, isn't that the coolant temperature one?
I got no idea how oil even gets there, but it was the first place it started seeping through.
I hope with your help I can resolve this before the spring comes and stop leaving dots of oil!
Bonus picture - my very leaky, but wide RT4wd civic wagon!
