1 - 4 of 4 Posts
1999 civic Hatchback
Ok guys i have a lil problem here that i would like to diagnose or confirm what i think the problem is..
Here are the symptoms:
2nd gear goes in well under normal driving..It does not pops out while accelerating or at WOT. It does pops out if im driving normal and i let go off the gas..you can see the shifter move if i accelerate or decelerate(sp?) but it only pops out if i take the foot out of the gas pedal and the car decelerates quickly(kind of makes a hard movement)..
If doing pulls at WOT from 1st gear its very likelly to miss 2nd and even sometimes 3rd gear..
Now....Im thinking is the Shifter bushings since my mechanic said theyre sloppy and theyre the OEM ones..Will putting Polyurethane shifter bushings solve my problem?
This started happening just some weeks ago..everything was perfect..Only thing new is the Clutch and flywheel.
kommon_sense said:
IMO poly shifter bushings are a must. However I'd really be looking at the rear motor mount. You ever had it changed?
I have the stock rear mount with the Polyurethane insert
1 - 4 of 4 Posts
