1 - 9 of 9 Posts
I'm starting to get a grind when I down shift into 2nd from 3rd. Even if I rev match to double clutch it still does it. I read some where it could be my mounts? Im pretty sure its the stock si trans in my 91 still.
Wagovan
well depending on how well your rev matching i would say synchros. which are usually noticeable first when downshifting and once it becomes a normal occourance it will happen when going into 2nd and just be worst when downshifting. I tend to just push in the clutch when coming to a stop but thats just my driving style.
99 integra ls-DD
Well if its that should I start looking for a new trans or can I fix that my self?
fork have nothing todo with trans, it sits on the spine between clutch and the tranny,
might just get new clutch kit while ur at it if its oem.
BMX bike
:3dtard:
whatever you are on I'll take two :bigok:
Explain to me the 4 shifter forks INSIDE the tranny that has NOTHING to do with the clutch.
I never said CLUTCH fork which you are trying to explain.
Now everyone is going "Four shifter forks, I thought there were only three?"
1 - 9 of 9 Posts
