1 - 7 of 7 Posts
has anyone hit 250hp or higher on a d16z6 using a tdo5 14b turbo or a evo III. and if so how much boost did it take?
civic coupe
Just to give you something to gauge off of a had a 14b on my y8 ( 140k miles ) boosting 6-8 lb’s totally stock 2.5 inch exhaust I hit 186 on a mustang dyno with a conservative tune dsm 450’s and p28 on crome…higher boost and a little more tuning I could have hit 200+
Try th search button and alo try
www.turbod16.com
I would assume somewhere around 8-15. BUT, psi is an erratic value. Meaning someone may hit 250hp @ 10 psi with a good tune, while someone w/o proper tuning would need more like 15ish. They say it's usualy 12 hp per pound of boost. 10 psi =120hp. 120+125= 245ish....this is all ballpark.
civic coupe
build it save up your money and do it right the first time as well......
man i wish someone woulda told me that b4 i blew mine up the first time hahahahaa
The Master Fabricator
See my VBPic Gallery.
I made 272 hp and 240tq on a small 16g (with 10cm turbine housing) at 15psi.
10:1 Comp...
1 - 7 of 7 Posts
