1 - 20 of 29 Posts
........DX/LX.........HX...........EX
1......3.461.........3.461......3.142
2......1.869.........1.750......1.869
3......1.241.........1.116......1.241
4......0.969.........0.857......0.969
5......0.710.........0.710......0.756
FD....4.111.........3.842......4.411
Info if from Factory Honda manual for 2001-2004 Civics.
Foshizznit! I new it was better than previous tranny's !!!
Discussion Starter · #7 ·
nope.
2001 + use cable linkage to shift.
PS might wanna add this as a sticky in the 7th gen forum.
D-Series Destruction Master
transzex said:
nope.
cable, as in...just like the 4th gen, or completely different.
transzex said:
nope.
If the problems is the cable linkage, I can say yes it fit. Just use the 01-5 civic shifter (with its plastic mounts) and clables and use your imagination to fit it on the car.
On Honda Tuning magazine they swap a K20 or K24 on an older civic. They cut the floor where the shifter is, use aluminum sheet to build a custom mount. Ask a friend who receive that magazine...
wow, you are so helpful, thanks for all of your information, and your sources!
:fairies:
You sure that hx 3rd isnt 1.166? That's what the 01-05 manual says.
yes the trannys out of 01-05 civics are the same as the older ones minus the linkage. you can bolt an 01 tranny to a Y8 or Z6 so ive read , ive never tried yet.
The Great Weldini
91 civic
How hard would it be to make it a 6 speed (matter of adding an extra gear, or is it a matter of getting a new mount able to handle the 7 gear settings [with reverse].)
I saw on another thread that it would be advantagous to swap first gear for a 2.75 gear, does that still apply to our DX/EX models?
Discussion Starter · #18 ·
You saying that the 05 manual has a typo or the earlier ones?
One of them has a typo which is quite common.
Discussion Starter · #19 ·
Discussion Starter · #20 ·
1 - 20 of 29 Posts
