1 - 20 of 26 Posts
S
I have a d15b7 in my 94 DX I have swapped the automatic trans. for manual 2 years ago the only trans. I could get at the time was a VX(CRAP). Now I need to replace my clutch and I have found a 2000 SI trans. with the case reading s20 B000 just want to make sure it will bolt up and the axles will still fit. the main shaft splines fit into my clutch disc hub so I don't see a problem but if any of you guy's know for sure it would be really helpful instead of finding out when the car is in the air....
A 2000 Si trans woulden't bolt on to your block. It's made for a B16. You sure it's not a EX trans?
Its a Ex/Si tranny out of 92-95 Z6 motor, Y8 tranny is S40..
That makes sense then. So it's the same as a EX tranny then?
Yep its just not 96-00 Ex tranny..
S
its from a 2000 SI and was told it will fit cause I was looking for a 97 EX 5sp
EX/SI have the same gear ratios? don't they
S
I know it didn't come from a B16A
would it not come from a d16 or d17
Well S20 = 92-95 Z6 tranny Ex/SI
S40= 96-2000 Ex/SI tranny Y8
S
In Canada to get a Bseries you have to get a SIR
or JDM
S
its at the dealership it may be s20 or s40 I will look when I get in to work in the morn.
all I was looking for was B000.above the filler plug......lol
it took 3 tries to get this one.
or JDM
no....I'm from Quebec and we have those model:
92-95 Si= D16Z6
No Si from 96 to 98, only ex
99-00 Si= B16a3
Maybe there is some difference in model in other province!?
Curious George
'99 LX Civic Sedan
berettagtz117 said:
Yep that is Y8 tranny!!
yeah ! that's what I got ! :)
lil better than y7 tranny, but not the JDM type-R civic B tranny gearing :(
S
Discussion Starter #18
way better than the VX transmission in it right now but tomorrow is the day that I'm installing the s40 transmission going to use the lightened fly wheel from the VX model we will see how it works with the d15.
S
Discussion Starter #19
I did the complete job this morning and the car is working great, pulling nice through all gears.. haha no grinding, popping out of gear its so sweet...
1 - 20 of 26 Posts
