1 - 9 of 9 Posts
first of all, whats your mos?
second of all
its the only wire on the compressor. unless youre looking for the chassis side of it
former 15s (Kiowa warrior mechanic)
1 wire is ground, the other is the one that gets plugged into the chassis side
check around the headlight area.
I'm not 100% sure on the 2000 civic but there should be 2 relays by the divers side headlight. The wire should go there.
Discussion Starter · #9 ·
Thanks guy for your help. After a little digging. I found the power wire connector. It is at the very bottom of the radiator. It's a grey clip with one red wire coming out of it.
1 - 9 of 9 Posts
