1 - 7 of 7 Posts
Contact: John (540) 250-5239
Condition: Good
Title: Clear
Motor:
1.6L SOHC Vtec (D16y8) Built by Rockville Ring and Bearing of Maryland
Forged Arias Pistons
Eagle Rods
ACL Race bearings
Ported oil pump
Gates (blue) racing timing belt
Stock head with ARP head studs
Stock motor mounts filled with urethane
Has about 5000 miles on the motor.
Turbo Kit:
Garrett t3/t4 57 trim with stage 3 wheel
Go-Autoworks cast manifold
Go-Autoworks intercooler piping with bead rolled ends
Greddy RS BOV
Tial Wastegate
Vented Valve Cover with Catch Can setup
2.5” Downpipe
3" K-teller exhaust with Magnaflow Muffler
Transmission:
Stock low miles EX tranny (replaced original due to losing 3rd gear)
ACT Streetlite flywheel
Exedy Stage 3 Clutch
Short Throw Shifter with Knockoff Skunk 2 Shift knob
New passenger axle seal
Fuel and Tuning:
Walbro 450lph fuel pump
Injector Nation 900cc injectors
Omnipower 3bar map sensor
MAC Electronic Boost Control Solenoid (Boost by gear enabled)
Zeitronix Ethanol Fuel Content Analyzer (input to ECU depending on ethanol percentage)
Innovate LC-2 Wideband with DB Blue Gauge
Digital Oil Pressure Gauge
Mechanical Boost Gauge
PO6 ECU Chipped with Neptune RTP Demon (for tuning)
Other mods:
5zigen 5n01r-c rims with new Goodyear Eagle GT tires
Progress Springs with Tokico Illumina struts (need to be installed)
Integra GSR Seats
Skunk2 Rear LCA's and Lower Rear Tie Bar
Steel Braided Front Brake Lines
Type R front lip
Mini H1 Hid Projectors with morimoto ballasts and 4500K bulbs (not installed)
New drivers Fender and Hood Installed
New Front Bumper (not installed)
New Taillight gaskets installed
The Good:
Tuned on Neptune by John Kerr of J-K tuning of Pennsylvania.
Made 361whp and 277tq on E85 @ 24psi (Dyno Sheet will be given to buyer)
Realized the injectors were being maxed out so I turned down the boost.
Fresh 4/17 VA State inspection
The Bad:
The body has some dings and dents.
Car has key marks on top of trunk.
No rear trunk carpet
No A/C. All components removed
Has a squeak in the front suspension somewhere.
Bought from a DSO member and this car will fly and is built right. Trying to keep it in the D Fam. I have done a few things to the car and bought a few new parts since I purchased it. I just don't need it right now and it needs to go.
Dang. If I wasn't on tour until August, I'd buy this as just a fun toy!
That's the whole reason I bought it. It is an awesome car, but sadly is a toy that I don't need right now.
Discussion Starter · #4 ·
Bump
That looks like a super buy and a blast. Almost impossible to get that much speed that cheap any other way. Wishing I had the space for it
1 - 7 of 7 Posts
