1 - 10 of 10 Posts
del Sol si '94
I see quite a few 3 inch downpipes. What power numbers would you see the benefit of 3 inch? 250hp or 300hp? Are there any guidelines to picking the size of your downpipe?
10 second daily driver :)
well while its a given that a 3 inch can flow more then a 2.5 you would be surprised at how much power can be made on a 2.5, a good example i can give you is my old CRX , it had a DSM turbo and they use a O2 housing and stock they are only around 1-7/8s inch opening i had mine ported out to close to 2 inch, then my exhaust was 2.5 the rest of the way back, and i made 305 whp and 265 tq, and ran mid 11s in the 1/4, many people was shocked when they heard and saw i did not have a 3 inch exhaust system.
the biggest guide line is space, but 3 in will do more than 300. if you have the space go for it by looking at you mods it seems you would benefit from the 3in
EDIT: in your mods list you spelled xenocron wrong
del Sol si '94
Thanks a ton! Thats exactly what i wanted to know. I think im gonna keep it simple with 2.5. Maybe go 3inch from the dp back?
if space allows it then you wont loose by doing it all 3 , but if you already have a 2.5 or space is tight then yeah you can go 2.5 to 3 , you just never want to go backwards like 3 to 2.5 .
del Sol si '94
You may as well do it all in 3"
Its gonna be atight fit in my del sol, with p/s and ac. And how much more power are you gonna make, and Im sure the 3inch is gonna affect the drivability some.
del Sol si '94
Hmm, good to know. Thank yous
1 - 10 of 10 Posts
