P
i'm looking at the kteller exhausts and do i want a 2.5" or go with the 3" also since it's a 93 ex do i need the bugs in the dp and the cat? also what size resognator do i want? cuz i want my car as quiet as possible.
You should be fine with the 2.5", but if you want you can go 3", as far as the bungs go I would say yes for the cat, not sure about the dp but im leaning toward yes, and the resognator it depend on what size exhaust yuo get. Hope this helps some....
P
i think imma go w/ a 2.5" dp and get their cat and then go w/ a 3" exhaust. why not? soo then what size regnator do i get? an does anybody know if i need a bug for my dp going on a 93 civic ex
O
3" is going to be louder. if your not goig to be running more than like 14psi then 2.5" is fine. if you plan on getting the newer kit and doing rods and pistons soon then 3"
P
and i can't find a 2.5" cat back at kteller and also what size resognator? is it just the bigger it is the quieter the exhaust will be?
