1 - 3 of 3 Posts
N
I have an 87 CRX Si and wanted to be sure that I can use a ZC tranny. will it bolt up to the Si block , they are pretty much identical outside right? Also what about the input shaft splines, can I use my existing clutch? thanks for the help - I'm sure this has been answered before but my search yeilded no results as "Si, CRX, 1st, and Gen" are all too small of words for the search to care abount apparently.
If the tag on the bell housing says its a CGxxxxx than yes you are good, if it says L3 its for a 88 or up, which will bolt up to the block but not the CRX chassis. I have been trying to get more info on the ZC trannys because I would love the longer gears in mine.
Cj
1 - 3 of 3 Posts
