1 - 19 of 19 Posts
Hello,
I just recently bought a 1998 civic hx 5 speed manual and as title says it has a CEL on. And searching for the cure. Currently does operate smoothly just no vtec engagement .
Code numbers found were
P1163
P0430
P-1457
Other info to say is running casting codes I did find it has the d16y5 block with the d16y8 head
Running on the civic hx ecu
Ideas or thoughts where to start?
Discussion Starter · #2 ·
Also wanted to mention that I also searched a bit and found out I think it should have a 5wire primary o2 but has a 4wire o2 instead.
Guessing they started a y8 conversion
Any help appreciated guys
And car is from Hilliard Ohio, so maybe old owner is a member?
Sloppy Jalopy
P1163 primary o2 slow response maybe wrong sensor
P0430 secondary o2 does it have a cat?
P-1457 evap all hunkydory or even hooked up?
So ...change ecu to allow y8ness
install cat or o2 sim
check evap vent valve function.
Discussion Starter · #4 ·
Ok yeah I was thinking I would at least need a p2p ecu for sure.
It does have a catalytic converter currently. But may not be functioning or clogged. Prob. Going to delete and use a o2 simulator.
On the primary it could be, I'm not sure what the previous owner did yet. I know I read that the primary o2 usually needs converted for y8 I thought.
head should match the ecu to make life a little easier
life is super simple for you my friend
d16y8 engine harness from any 96-98 manual ex
d16y8 ecu from any 96-98 manual ex
BOOM. you have your problems sorted out as far as performance
EVAP could be as simple as previous owner mucking about under the hood.
Grab a vacuum diagram, trace a few wires, and have fun on the journey of no CEL
lol
Discussion Starter · #7 ·
Copy that, already got a line on the ecu. Going to put that in and see what happens, if it still has any issues, I will get the harness as well, may do that anyway.
But yeah lol oh the fun I will have doing vacuum line diagnostics.
Discussion Starter · #8 ·
Ok so I just tried the new p2p ecu which is a 5 speed manual one and car seems to operate good and vtec does engage etc. but has a CEL still which I will get checked hopefully tomorrow.
But now it idles like crap. Sits at 200 rpm and just about wants to die. Any ideas to look into?
Thanks in advance
timing. google how to set it while jumping the service connector. also, bleed coolant
Discussion Starter · #10 ·
Copy that I will take a look into it. I will double check coolant but should be good, checked it when I bought the car.
Discussion Starter · #11 ·
Anything else that could cause this I should be checking out?
Discussion Starter · #13 ·
Hoping so
94 Integra
Keep in mind the HX used the same head casting as the EX. The difference was the cam & rocker arms. If you look under the cover and see roller rockers, it's not a full y8 head.
As far as crappy idle, the Y8 uses a 2-wire model while nearly everything else 96+ uses a 3-wire. If it's the HX intake & IACV, the EX ecu won't be able to control it - and idle will be ~400rpm or lower.
Discussion Starter · #15 ·
You just solved it I would say likely. When I tried it, I had the p2p ecu, the hx manifold and y8 head.so I am thinking the iacv is the idle issue then. How do I need to go about solving that? I recently picked up a spare y8 head for cheap with a manual y8 intake complete as well with the injectors and such.
Discussion Starter · #16 ·
Problem solved pretty much, decided to go another route and went back to obd1 and used a chipped p28 with jumper.
Discussion Starter · #17 ·
So I just installed a ryewire obd2a to obd1 jumper and obd1 ecu with a d16y8 tune on it. Now cels are all gone but it's idle is very choppy
Any suggestions now? Maybe the iacv?
To clarify setup:
D16y5 bottom end
D16y8 head
D16y5 intake and exhaust manifolds
Intake and soon adding header
Discussion Starter · #18 ·
Also to help, I have tried running couple ecus. As well as running p2p ecu without jumper to have very similar behavior
I am reading that I may need to do something with iacv wiring?
Discussion Starter · #19 ·
Topic can be closed. Just needed to add some y8 injectors
Runs like a champ now
1 - 19 of 19 Posts
