21 - 27 of 27 Posts
Discussion Starter #22
Ok so it has set and i have done nothing with it . I went to recheck the compression and now im showing no compression at all???!!!??? How does that happen? And this is all a bit confusing seeing as it ran before i did the head swap. So technically it should run after right.?
a) are you cranking with the throttle wide open?
b) is the cam set properly and youre doing them in order?
c) this is not the proper section to sell items. follow the rules
Discussion Starter #25
No i forgot to open throttle all the way. i do believe the cam is set properly. How could I tell if its not and checking in order from the gear to the dis.
Discussion Starter #26
Sorry for the improper posting of my engine for sale still havnt gotten the 90 or whatever it is posts, and however many days it is before I can post in the listings.
find the way to line the timing marks on google or Haynes manual. pull the dist plug before you try and crank it again
21 - 27 of 27 Posts
