thats quote material...only thing that needs stickied is the search button![]()
thanx that helps me out alot yea i try holding it in and it still pops out is it easy to do cause if so i'm pullin motor anyways i'll do it myself are there any special tools i need?![]()
You should also replace the 1-2 shifter fork, esp. if you tried to hold it into 2nd.
New ISB/seal/thrust washer and 1-2 shifter fork, would be about $200 including parts for me to do it, if the tranny was closer......your over 200 miles away!
