1 - 2 of 2 Posts
the other day my reverse went out and the same time it doesnt want to go into 4th gear its make a grinding nosie. its a auto. so i drive it anyways in 3rd gear even when iam on the e-way. at 60mph at 3700rpm's . what do you guys think . is the tranny go to blow up on me??etc.
well autos dont have "gears"...and the only gear in trans axles is run by a chain...correct me of im wrong. autos run off fluid pressure and pump speed...check your tranny fluid and see if it has any metel flakes in it..if it does, drive it till it quits(which wont be long) or snatch it out and replace it with a manual!!
1 - 2 of 2 Posts
