1 - 10 of 10 Posts
I currently am running a 12lb fly... how I will be rebuilding my Y8 in the spring... and I am going to be installing a new clutch, is it worth it to get an even lighter flywheel.... like 8 lbs? maybe or should I just keep the 12lb?
98 Civic EX
how much power you going to have? the lighter flywheel will require more power to effectivly use it
R2.....Zap Balls
94 Ex coupe
keep the 12lb. The only reason I would go any lower is if you were going N/A.
I dont like my 12lb flywheel why go lighter...?
i do some stop/go driving it sux having to rev the engine up high just to move
i am running a act streetlite. i dont rev any higher taking off then anyone else with a stock flywheel. sucks to lose that little low end power, but other then that its simply fine. and that is even running a stiff clutch. i honestly dont see why people think they have to rev higher to take off with a lightened flywheel.
1 - 10 of 10 Posts
