What's good Honda peeps. I would really appreciate some insight here. I tried to fire my engine last night with no luck. Fuel pressure primes to 40ish, drops to around 27 while cranking and bleeds off to zero. I fixed a couple leaks we had in the fuel system. I pulled a plug and watched it arc so I know I'm getting spark. I have not pulled a plug after cranking more to see if there is fuel so my thought is maybe the injectors aren't firing. I noticed that while I'm cranking my short term fuel trim is pegged at -100. So if I am not mistaken the ecu is pulling fuel. I have high impedence 1000cc Bosch EV14s in right now, I adjusted the dead times per the spec card that the injectors came with.
Here's a break down of engine and ecu components in case this helps.
Everything is new never ran. D16Z6, turbo, 1000cc EV14 injectors, AEM 340 pump, Vitara pistons, Speed Factory no notch rods, Ferrea 6000 turbo valves, Supertech keepers, Brian Crower BC0070S steel springs and retainers, Speed Factory street savage camshaft, Skunk 2 intake and 70mm throttle body, Burton Racing 4bar map sensor.
Any ideas on what to try? I'm gonna pull a plug and see if I have fuel. If there's no fuel in the cylinder should I try the base map with the stock injector settings and see if that works?
Also the ecu is a 1720 board, s300 v3. I added PWM and vtec. We installed into a buddies car with a b18 and base map, it fired right up so the ecu is working.
