1 - 12 of 12 Posts
Civic si
Hi everyone from Turkey
I build this setup last year on my 94 civic si
75,5 jcc p29 pistons-npr rings, d17 crank-rods-oilpump, oem head gasket, daido bearings, 1mm oversize flattop int-ext valves, golf Ball cylinder head port design (handmade by me) intake manifold porting and polishing, 65mm t/b, ebay headers etc... soft tune on Mustang dyno gained about 180hp at this time... more photos comes...
Civic si
Discussion Starter · #5 ·
Hi! we will hard tune it next month i share dyno results on this post i dont want any mechanically change for now..! I use stock cams on it only change cam degrees with adjustable cam gears
A Captiva Blue Si Ha
How in the world are you using a d17 crank/rods and p29 pistons, without the pistons hitting the head? I punched your combination into zeal auto werks and those pistons are 0.047" out of the hole....
Are you using a huge head gasket?
Or does it not matter, since that is what people normally mill off the head and block on these things anyways?
Civic si
The dyno seems very "generous," with 180/180 for HP and torque for your setup.
I tune it on road next weekand and share updated dyno or race logic diagrams
I was share this photo in albume... I trimmed around pistons head about 1mm. Normally pistons up to 1.2mm block and hit the cylinder head thats right ??
This is the photo
Sorry I cant upload The photo
This is the photo
Oh, okay, very cool. I can see where you milled 1mm of of the top of the pistons. Good idea. :punk:
1 - 12 of 12 Posts
