1 - 17 of 17 Posts
No more Honda's :-(
i thought that the crank main's were different? or is that just rod bearings? if the cranks are the same that would be great!
What are you talking about??????
Crankshaft doesn't interact with the oil pan.
what about 96 and up? Some Y8's have the aluminum pan, and I was wondering this the other day. If you used the pickup from the Y8, along with the pan, could this bolt on to any D motor? Good questions!
-josh-
The d16a6 z6 y7 and y8 use the same crank. Im pretty shure that a6 and z6 rod and main bearings are the same. I also know that a d17 oilpan will fit a d16.
1 - 17 of 17 Posts
