hello guys , my first post here on my first Honda - so i'm still learning and may use wrong phrases or diagnosis.
so:
  • during a long ride the speed sensor suddenly failed - stopped showing the speed
  • stopped a few minutes later to check - the car won't start
  • i still had a healthy starter (new starter, battery, plugs & wires) - so i went and replaced the distributor (for now with a used one)
  • connected all & tried to start the car : heard a shortcut noise and noticed the connector was swole and burned.
  • the car do start with carburator spray or if i'm creating vacuum with my hand instead of the air filter.
*adding pics of the connector
check for the fuse to the vss. if its blown the car wont start. would also help to know what the car is
fuse 15, give it a look over and let me know what you find
139471
