This car has been in the shop for over a week.. its kind of a long read but basically the car is getting no spark.
Customers car was driving down the street when they heard a "pop" and the car suddenly stalled. When I arrived, I noticed the fuel pump was not priming. I found that the fuel safety cut off switch had tripped. I reset it and the fuel pump started working but the car still would not start.
I towed to my shop and it has codes for CMP sensor circuit failure. I noticed the CKP sensor was totally cooked and falling a part. So, I replaced both of them.
The car also has a code for MAF sensor low voltage. I check for clogged air filter, cleaned the already impeccably clean MAF sensor.. no change.
Also getting a code for Bank 1 catalytic below efficiency. and bank 1 sensor 2 beyond maximum threshold.
A friend of mine with a Tiburon had the same issue with his CKP, ended up having to replace the toothed wheel that the sensor reads along with the sensor.. I don't understand how a toothed wheel inside the crank case could ever become damaged/need to be replaced but, if it happens, it happens.
I replaced the catalytic just because it needed one.. turns out the cat was completely gone...
So, I preplaced CKP, CMP sensors and bank 1 cat. No start. The coils are not producing any spark.
The coils are supposed to read .6ohms on the primary winding. They were all reading 2+ohms. The windings were rusty and bulging.. So I replaced them since the hot wire (green) going to them is reading battery voltage when the key is in the on position, as it's supposed to, and the service manual says to replace them if they are reading more resistance than they are supposed to.
Still no spark. What is going on?
