1 - 4 of 4 Posts
A friend of mine decided to replace his steering wheel to one of those quick disconnect one's and now his srs light is on. I think its because of the steering wheel not having an airbag anymore. But anyways is there a way to turn that annoying srs light off. thanks
1993 ej1 P.O.S
1) remove screws for molding for cluster (i.e screws and such) 2) remove said cluster (3 spin said cluster around (not to fast or youll drop it!)
3) find light that lights "SRS" light 4) remove light 5) take break because that was ALOT of work 6) put all back together 7) start car and have fun hitting MAD Vtaks :yes:
Is it a good idea to stick a jumper wire in the yellow connector under the driver side dash or will it not make go away
1 - 4 of 4 Posts
