1 - 10 of 10 Posts
since you guys know the d17 manifold is plastic.. so i want to run 20 psi of boost n my d17 and im not sure if the manifold will be able to handle that..
im running 9 psi but now i want to change my internals to boost the thing up to 20 psi. which internals should i use and where can i get it from...
thanks
have you researched anything? at all? go look at dezod.com ... oooh and aaahh at all the shiny parts. they have just about every part you need to fully build an engine. the only options for manifold are a modified d16y8 intake mani, or a custom made one. or finding a used one from gerry at jdmfabtech... but good luck with that.
I second that. Please search. Here, 7thgen, HT, everywhere. The internet is your friend. Just read before you start asking really general questions. Odds are it's been answered before.
'02 Civic LX Coupe
Of course Grounded is correct, he know's his shit. But to second that...most people go with the y8 IM. Probably the easist and definately the most common one to do. Still requires mounting modifications and i believe a fuel return line is added too.
Honda Civic
Do some research first. Learn what you're doing to your car before you attempt it and blow it up.
Here are some links to get you started:
Turbo essential information:
http://d-series.org/forums/showthread.php?t=77291
Contains a bunch of links for more info:
http://d-series.org/forums/showthread.php?t=102717
Some more:
http://www.superhonda.com/forum/f87/wanting-boost-your-d-series-check-here-331005/
Some info about your the d motor:
http://www.superhonda.com/forum/f87/d-series-tech-archive-218226/
The most comprehensive(but not complete) tuner directory that I know of:
http://www.honda-tech.com/showthread.php?t=2368887
this link contains many FAQ that you might have:
http://www.honda-tech.com/showthread.php?t=1024174
As for parts, I would highly recommend
http://www.rcautoworks.com and http://www.go-autoworks.com/
Welcome to dark side.
95 EG coupe
the d17 is similar to the y8 and y7 same style head so as far as intake manifold goes u should be able to slap a y8 manifold on with a little modifiction
Close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close
1 - 10 of 10 Posts
