1 - 12 of 12 Posts
Ek Hatch/09 Ruckus
ok, when i first crank the car up it runs good and no lights are on, but once i get a few miles down the road and the engine warms up the check engine light comes on. What do you think it could be? i was thinking it might be an 02 sensor but im not sure, just want to get some other peoples ideas
91 CRX Si
o2 is a common problem. Does the car stutter or stumble upon acceleration once the light is on?
08 H-D Ultra Classic
O2 sensor heater ???
91 CRX Si
del sol
could be 02 or idle air control valve or many different things more info would be great.: tune up history, miles, exact engine, mods. ect...
Holy crap....
Ok
1. pull the carpet in the pass side floor board back (the area were your feet go"
2.there should be a metal plate with a hole in the middle/ or plate is gone and ecu is visible
3. the ecu has a red light that flashes
4.Count how many flashes there is when its done the flashing will restart
Give us the number of flashes OR google
(90 civic ecu codes)
Ek Hatch/09 Ruckus
ok well that motor blow up lol so i droped a obd1 jdm d15b into it and it still does it but now its just throwing a knock sensor code and some other one i cant remember, but sometimes it does want to stutter upon acceleration at lower rpms but i was told the light weight flywheel could be doin this. and thanks for all the help guys.
1 - 12 of 12 Posts
