92-95 EX differential in 88-91 Case shim issue - D-series.org
Old 02-15-2006, 05:37 AM   #1 (permalink)
K2e2vin's Avatar
Rep Power: 18 K2e2vin It's a JDM Star Bitches....
Send a message via AIM to K2e2vin
Default 92-95 EX differential in 88-91 Case shim issue
Ive posted this on H-T but got no response.
I've obtained a EX differential from a 92-95 Civic EX. I've tried to measure the clearance of the thrust shim but looks like it's a tight fit(im not sure about the thickness of the shim though; I have no caliper to measure it). The Helms manual states that it's supposed to be a .10mm max side clearance, nothing about a minimum clearance. Would an tight thrust shim cause problems to the bearing or should I try to make the clearnace a little looser? btw, this is all in a 88-91 DOHC ZC transmission with 88-91 countershaft.
-Kevin N. E.
1992 Honda Accord LX coupe
K2e2vin is offline   Reply With Quote Quick reply to this message
Old 02-15-2006, 12:30 PM   #2 (permalink)
gonna have to get the tools to measure it.
Feeler gauges and snap ring tool.
Tight shim and the case will NOT go back together.
Old 02-15-2006, 12:37 PM   #3 (permalink)
K2e2vin's Avatar
Yea I've tried to measure it(even with out bolting it); the smaller feeler gauge I have wouldn't fit in there; .038mm. Should I just purchase a 1mm shim and start from there?
-Kevin N. E.
Old 02-15-2006, 01:42 PM   #4 (permalink)
K2e2vin's Avatar
OK I just measured the clearance without the shim(bolts torqued to 20lbs) and it's around 0.102mm It's really close to the .10mm limit; should I run a shim that's milled down to .10mm?
-Kevin N. E.
Old 02-19-2006, 04:20 PM   #5 (permalink)
K2e2vin's Avatar
Just an update for those wondering or curious about this setup; Turns out the bearing wasn't pressed in all the way. I took a 40mm socket and hammer to it; put in the shim that was already in the transmission and ended up with about .07mm of clearance.
-Kevin N. E.
iconAll times are GMT -8. The time now is 10:12 PM. | Welcome to Forum, please register to access all of our features.
