88-91 CRX Si tranny VS 96-00 EX tranny - D-series.org
Old 12-30-2005, 10:36 PM   #1 (permalink)
i love honda's Avatar
Rep Power: 15 i love honda will become famous soon enoughi love honda will become famous soon enoughi love honda will become famous soon enough
Default 88-91 CRX Si tranny VS 96-00 EX tranny
Which tranny is better between the 2 and why? Or is there even a real difference?
UNnaturally Aspirated!
-SOHC ZC vtec
-XTD stage 3 clutch & 8lbs flywheel
-APEXi IHI ball bearing turbo kit
-ARP head studs
-10lbs daily
-Tuned on Crome Pro
220whp and 182wtq!
i love honda is offline   Reply With Quote Quick reply to this message
Old 12-31-2005, 09:43 AM   #2 (permalink)
mmmmm sexy bay
jimmyb34's Avatar
Rep Power: 50 jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
iTrader Score: 29 reviews
Send a message via AIM to jimmyb34
if you already have one stay with it, if you have a newer car getting the crx si tranny in it is to hard to do anything
same goes for the other way
jimmyb34 is offline   Reply With Quote Quick reply to this message
Old 12-31-2005, 11:02 AM   #3 (permalink)
are you trying to choose which one to use? because unless you have a lot of fabrication skills or a ton of money, good luck getting them to work in swap with each other
[email protected]
Old 01-01-2006, 06:32 PM   #4 (permalink)
Rep Power: 0 DirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatness
Cable vs Hydro FOR THE WWE CHAMPIONSHIP
DirtyDC4 is offline   Reply With Quote Quick reply to this message
Old 01-01-2006, 11:26 PM   #5 (permalink)
Oh Im not swapping or looking to swap. I have the EX tranny on my y8 right now. I was just wondering which one seemed to be better cause one of my good friends has an 88 CRX Si. I guess I should've posted in the General Tech sectional. Sorry about that...
-SOHC ZC vtec
-ARP head studs
-10lbs daily
-Tuned on Crome Pro
220whp and 182wtq!
Old 01-02-2006, 01:59 AM   #6 (permalink)
.937 CRX 4th OVER the .909 92-00 4th gear..........
But it is not a direct swap
Oh yeah, I have 2 trannys out there setup like that.
shifting at 7200 rpm, 92+ EX/Si tranny......
drops to 5236 rpm with .909 4th
drops to 5400 rpm with .934 4th
not much of a difference, but that extra 160 rpm makes it a little more fun. Not something I'd rip a tranny apart to do, but if it is that far apart.......
iconAll times are GMT -8. The time now is 01:45 AM. | Welcome to Forum, please register to access all of our features.
