88-91 AWD 6spd - D-series.org
Old 12-27-2005, 07:40 PM   #1 (permalink)
EFHATCH1990's Avatar
Rep Power: 14 EFHATCH1990 is nobody
Send a message via AIM to EFHATCH1990
Default 88-91 AWD 6spd
I was wondering if any body knows the gear ratios on the 88-91 AWD 6spd civic tranny? or if there are any differances between the years. thanks.
-Jason
EFHATCH1990 is offline   Reply With Quote Quick reply to this message
Old 12-27-2005, 11:43 PM   #2 (permalink)
What are your plans for the tranny?
You can't swap it.......nor use any internal parts from it.
Old 12-28-2005, 04:39 PM   #3 (permalink)
why wont it swap in? it bolts to an A6 right? or is the chassis diffrent from the AWD civic wagon to the civic hatchback of the same years?
Old 12-28-2005, 07:20 PM   #4 (permalink)
The H Badge is it!
SOHC_Rules's Avatar
Rep Power: 20 SOHC_Rules is hot as a volcanoSOHC_Rules is hot as a volcano
iTrader Score: 30 reviews
Send a message via AIM to SOHC_Rules
honda made a 6 speed for the civic?
and the real time 4wd system is very weak.. cant handle more than 180hp or so... at least thats what ive heard
xbox live: turboa6
play COD BO2 and Forza 4
SOHC_Rules is offline   Reply With Quote Quick reply to this message
Old 12-28-2005, 07:48 PM   #5 (permalink)
Rep Power: 0 russianswty is nobody
that be really cool, but then i was thinking about it and i dont know if it would fit, and how id fit. and also the gear ratios.
russianswty is offline   Reply With Quote Quick reply to this message
Old 12-28-2005, 10:58 PM   #6 (permalink)
diegoaccord
Is he REALLY going to break 180 HP?
Old 01-02-2006, 06:03 AM   #7 (permalink)
K2e2vin's Avatar
Rep Power: 18 K2e2vin It's a JDM Star Bitches....
Send a message via AIM to K2e2vin
Is the old school 4wd even real time? I thought it was just a simple all-time awd.
-Kevin N. E.
1992 Honda Accord LX coupe
K2e2vin is offline   Reply With Quote Quick reply to this message
Old 01-02-2006, 08:19 PM   #8 (permalink)
the CRV uses a dual pump system and the civic AWD used a viscous coupling. I wanted to just throw the 6SPD in and not connect the rear driveshaft B/C I have a 4SPD right now and it is teh ghey and I can pick up a 6spd in good condition for around $50
Old 01-03-2006, 02:35 AM   #9 (permalink)
the shifter setup is cable vs your rod setup.
Just get a 89-91 DX tranny and be done, listen to me for once!
Old 01-17-2006, 03:47 PM   #10 (permalink)
bense's Avatar
Rep Power: 14 bense is starting to learn the ropesbense is starting to learn the ropesbense is starting to learn the ropesbense is starting to learn the ropesbense is starting to learn the ropesbense is starting to learn the ropes
were they really even 6speed? what were the ratios?
bense is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 06:36 PM   #11 (permalink)
granny low was not condisidered a normal gear, more like a crawling gear.
Old 01-17-2006, 11:03 PM   #12 (permalink)
bense's Avatar
similiar to a "bull gear" ?
Old 01-18-2006, 12:35 AM   #13 (permalink)
SilentWrath*'s Avatar
Rep Power: 18 SilentWrath* It's a JDM Star Bitches....
SilentWrath* It's a JDM Star Bitches....SilentWrath* It's a JDM Star Bitches....
iTrader Score: 34 reviews
you need a 5spd dx tranny??? im in cola sc..... have one in the garage...
_________________________________________________
'91 CRX Si Project: DD Status. 9psi.
キタ━━━━━━(゚∀゚)━━━━━━!!!!!
<stock block d15b build complete.>
*Turbo Fabrication by Greg @ GO-AUTOWORKS.*
*Tuned by Howard @ RLZ Engineering.*
SilentWrath* is offline   Reply With Quote Quick reply to this message
Old 01-18-2006, 08:32 AM   #14 (permalink)
bense's Avatar
no way, i have like 8 transmissions myself
Old 01-18-2006, 09:36 AM   #15 (permalink)
thats all?
Old 01-18-2006, 11:20 AM   #16 (permalink)
bense's Avatar
dare I ask how many you have?
Old 01-19-2006, 08:56 AM   #17 (permalink)
I ran out of fingers and toes.......now thinning out the stock......
iconAll times are GMT -8. The time now is 01:44 AM. | Welcome to Forum, please register to access all of our features.
