1999 D16Y7 Manual Tranny Problems - D-series.org
Old 12-21-2005, 03:48 PM   #1 (permalink)
Ohh...Uhh...
Default 1999 D16Y7 Manual Tranny Problems
As the title says, I have a 1999 Civic Dx with a manual tranny.
I've been having some problems when in gear, I hear a grinding sound. So far i have not had problems getting the car into gear though. I stopped driving the car because the grinding got too loud, sometimes i hear a pop, kinda like a bad axle.
I was wondering what is the best way to diagnose without removing the tranny.
Thanks in advance guys.
Old 12-21-2005, 06:27 PM   #2 (permalink)
Ohh...Uhh...
I added about a quart of mobil 1 5w30 engine oil, the grinding went away for the most part, however it seems that it wants to pop out of gear sometimes (esp. 1st & 2nd). Tomorrow i will drain the fluid and use honda fluid instead, see what happens.
Old 12-24-2005, 02:28 PM   #3 (permalink)
Ohh...Uhh...
I found a leak from the transmission seal on the drivers side axle. It also moves about .25" up and down. The axle is fine, its just leaking from the seal. Im wondering what pats by the drivers side transmission seal are the most likely to break down. Also, am i going to have to take the case apart?
Old 12-24-2005, 04:11 PM   #4 (permalink)
The H Badge is it!
SOHC_Rules's Avatar
Rep Power: 20 SOHC_Rules is hot as a volcanoSOHC_Rules is hot as a volcano
iTrader Score: 30 reviews
Send a message via AIM to SOHC_Rules
u probably just had low fluid to cause the grinding noise, and the axle seal is probly shot
no, u should just be able to pop the axle out and replace
xbox live: turboa6
play COD BO2 and Forza 4
SOHC_Rules is offline   Reply With Quote Quick reply to this message
Old 12-24-2005, 09:12 PM   #5 (permalink)
if inner cup is moving .25", bearings are toast, start looking for another tranny.
Rebuild kit for your tranny is $150-200, plus time and labor......
Old 01-07-2006, 08:36 PM   #6 (permalink)
Ohh...Uhh...
Update: Well, i ordered a set of differential bearings, about $50 (majestichonda.com). Tomorrow, i will install a '92 cx tranny, while i fix the other one's bearings. Should I look out for axle fitment issues or anything of the sort? Any tips, let me know.
Old 01-07-2006, 09:00 PM   #7 (permalink)
shifty35's Avatar
Rep Power: 16 shifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to all
I like this man, he's doing it himself. :tu:
I'd rather fork over $200 and rebuild my own tranny then buy one in suspect condition.
What is it and will the doom hit the valve when vtec is engaged?
'00 Honda Insight - the commuter, 70+ mpg
'90 Mazda Miata - Weekend Fun Car
'04 Toyota Prius - Wife / family car
shifty35 is offline   Reply With Quote Quick reply to this message
Old 01-08-2006, 11:31 PM   #8 (permalink)
but what about the inner workings?
Yes I learn by fucking up a few myself.
Old 01-10-2006, 06:57 AM   #9 (permalink)
shifty35's Avatar
Eh, it's the only way to learn. With a service manual, the right tools, and some patience... it's not too bad.
Besides, if you break it... you just buy another one, which is where you were before anyway.
iconAll times are GMT -8. The time now is 02:09 AM. | Welcome to Forum, please register to access all of our features.
