2000 si trans. - D-series.org
Old 11-29-2005, 01:18 PM   #1 (permalink)
sativa76
Default 2000 si trans.
I have a d15b7 in my 94 DX I have swapped the automatic trans. for manual 2 years ago the only trans. I could get at the time was a VX(CRAP). Now I need to replace my clutch and I have found a 2000 SI trans. with the case reading s20 B000 just want to make sure it will bolt up and the axles will still fit. the main shaft splines fit into my clutch disc hub so I don't see a problem but if any of you guy's know for sure it would be really helpful instead of finding out when the car is in the air....
Old 11-29-2005, 03:39 PM   #2 (permalink)
Dweezil's Avatar
Rep Power: 17 Dweezil is a name known to allDweezil is a name known to allDweezil is a name known to allDweezil is a name known to allDweezil is a name known to allDweezil is a name known to allDweezil is a name known to allDweezil is a name known to allDweezil is a name known to allDweezil is a name known to all
Send a message via AIM to Dweezil Send a message via Yahoo to Dweezil
A 2000 Si trans woulden't bolt on to your block. It's made for a B16. You sure it's not a EX trans?
`90 CRX Si, Z6 intake, axel back fell off, hood flew off, needs windshield.
Arrogent?
No, I, like a lot of people on this site, don't have time for dumbasses that type like a cat with downs syndrome.
P28 Clone - $125 Each
Unchippable P28 - $65
Dweezil is offline   Reply With Quote Quick reply to this message
Old 11-29-2005, 03:46 PM   #3 (permalink)
Rep Power: 0 berettagtz117 is a Top Aussie
berettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussie
iTrader Score: 17 reviews
Its a Ex/Si tranny out of 92-95 Z6 motor, Y8 tranny is S40..
berettagtz117 is offline   Reply With Quote Quick reply to this message
Old 11-29-2005, 03:53 PM   #4 (permalink)
he's from Canada, the models are different there
[email protected]
Old 11-29-2005, 03:55 PM   #5 (permalink)
Dweezil's Avatar
That makes sense then. So it's the same as a EX tranny then?
Arrogent?
Old 11-29-2005, 03:57 PM   #6 (permalink)
Yep its just not 96-00 Ex tranny..
Old 11-29-2005, 04:21 PM   #7 (permalink)
sativa76
its from a 2000 SI and was told it will fit cause I was looking for a 97 EX 5sp
EX/SI have the same gear ratios? don't they
Old 11-29-2005, 04:23 PM   #8 (permalink)
sativa76
I know it didn't come from a B16A
would it not come from a d16 or d17
Old 11-29-2005, 04:24 PM   #9 (permalink)
mmmmm sexy bay
jimmyb34's Avatar
Rep Power: 50 jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
iTrader Score: 29 reviews
Send a message via AIM to jimmyb34
in canada your si is = to our ex
people didnt see you were from canada before posting saying tis from a bseries
it will work just fine for you
jimmyb34 is offline   Reply With Quote Quick reply to this message
Old 11-29-2005, 04:29 PM   #10 (permalink)
Well S20 = 92-95 Z6 tranny Ex/SI
S40= 96-2000 Ex/SI tranny Y8
Old 11-29-2005, 04:32 PM   #11 (permalink)
Cool User Title Here
Honda4VW's Avatar
Location: 7.5 hours north of Modshxcivic, 6.5 hours north of Rexinre's house (he says only 5 hours) (MAINE)
Rep Power: 24 Honda4VW is hot as a volcanoHonda4VW is hot as a volcano
Honda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcano
Send a message via AIM to Honda4VW Send a message via MSN to Honda4VW Send a message via Yahoo to Honda4VW
Good call....You deserve some rep
Honda4VW is offline   Reply With Quote Quick reply to this message
Old 11-29-2005, 04:33 PM   #12 (permalink)
sativa76
In Canada to get a Bseries you have to get a SIR
or JDM
Old 11-29-2005, 04:35 PM   #13 (permalink)
sativa76
its at the dealership it may be s20 or s40 I will look when I get in to work in the morn.
all I was looking for was B000.above the filler plug......lol
it took 3 tries to get this one.
Old 11-30-2005, 08:49 AM   #14 (permalink)
sativa76
S40 B000
Old 11-30-2005, 12:59 PM   #15 (permalink)
S40 B000
Yep that is Y8 tranny!!
Old 11-30-2005, 04:27 PM   #16 (permalink)
B20BbenN's Avatar
Rep Power: 15 B20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropes
or JDM
no....I'm from Quebec and we have those model:
92-95 Si= D16Z6
No Si from 96 to 98, only ex
99-00 Si= B16a3
Maybe there is some difference in model in other province!?
B20BbenN is offline   Reply With Quote Quick reply to this message
Old 12-02-2005, 05:35 PM   #17 (permalink)
Curious George
Belette's Avatar
Rep Power: 18 Belette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatness
yeah ! that's what I got !
lil better than y7 tranny, but not the JDM type-R civic B tranny gearing
Turbo D16y7/8
Setup in building:
Video of my old setup:
Awesome Photography Thread:
Belette is offline   Reply With Quote Quick reply to this message
Old 12-02-2005, 06:34 PM   #18 (permalink)
sativa76
way better than the VX transmission in it right now but tomorrow is the day that I'm installing the s40 transmission going to use the lightened fly wheel from the VX model we will see how it works with the d15.
Old 12-03-2005, 11:42 AM   #19 (permalink)
sativa76
I did the complete job this morning and the car is working great, pulling nice through all gears.. haha no grinding, popping out of gear its so sweet...
Old 12-04-2005, 12:06 AM   #20 (permalink)
best mod ever!
iconAll times are GMT -8. The time now is 01:52 AM. | Welcome to Forum, please register to access all of our features.
