97 ex auto p0175 - D-series.org
Old 04-22-2018, 09:20 PM   #1 (permalink)
Rep Power: 0 Nchonda is nobody
Default 97 ex auto p0175
Was driving home from work and cel pops on. Followed but speedo/tach not working and gears basicly in limo mode. Got home turned it off, went to start....nothing. Pulled code p0175 input/turbine shaft speed sensor circuit. Is the trans toast or should I just replace that along with solenoids? Thanks
Nchonda is offline   Reply With Quote Quick reply to this message
Old 04-23-2018, 03:10 PM   #2 (permalink)
Not sure why you are worried about the transmission?
P0175 means you are running too rich.
Could be something pinching the fuel return hose, a stuck open injector, or a very slowly closing injector (generally clogged up), or could be an O2 sensor that is simply reading bad.
Pull the spark plugs out, compare them to one another, and compare them to online-available plug condition charts, and see what is happening.
Running too rich can imitate a limp mode if its killing a ton of power by not allowing the ignition system to function properly.
Old 04-23-2018, 03:35 PM   #3 (permalink)
My mistake. P0715
Old 04-23-2018, 03:36 PM   #4 (permalink)
Got to love iPhone keyboards đŸ¤£:joy:
Old 04-23-2018, 03:58 PM   #5 (permalink)
Side question, could a failing alternator thatÂ’s not providing enough power to said sensors be the issue?
Old 04-23-2018, 10:33 PM   #6 (permalink)
with the known wiring issues on back side of the motor, even a Honda TSB about it, things go haywire.
transzex is online now   Reply With Quote Quick reply to this message
Old 04-24-2018, 03:11 AM   #7 (permalink)
download a civic tech manual and test some stuff out. Pull trans solenoids off and make sure their screens are clean.
Else try this
http://www.justanswer.com/uploads/Ho...023457_zzz.pdf
Its honda's statement basically saying flush the transmission with 3-4 drains and refills, and then replacing the linear solenoid.
Old 04-24-2018, 05:22 AM   #8 (permalink)
Right on thanks guys. Much appreciated
iconAll times are GMT -8. The time now is 09:14 PM. | Welcome to Forum, please register to access all of our features.
