98 civic trans issue help - D-series.org
Old 09-27-2015, 03:35 PM   #1 (permalink)
Rep Power: 0 kurokageEK is nobody
Default 98 civic trans issue help
i bought a 98 civic with a blown motor. the trans came with. The dude i bought it from said he ran nitrous...is the trans still usable?
I bought another motor put a new flywheel and clutch kit on it. Now i drove it out of my driveway it went into 1st gear, no problems. got it all the way up to 40mph in 4th went around the block a couple times. Got to to stop sign took off in 1st gear and then i got on it a little in 2nd and it revved right up. And quit shifting. I pulled to the side and tried to put it in gear, trans was making a grinding noise in every gear you put it in and would not move even in reverse. I'm guessing the trans is done. But not sure.
Any one else got any suggestions?
thanks in advance.
Also idk if it matters i when i bought the motor it had a auto trans on it but i took all that off and put a new clutch and flywheel for 5speed. Any help i'd apprieate i need this car done ASAP.
(When I was trying to bolt up the trans to the flywheel, the trans resisted and wouldn't sit flush... The was about a small gap. We put the bolts and it cinched the gap, then we drove it after. Could this have also been a problem? Because the shaft was worn?....)
kurokageEK is offline   Reply With Quote Quick reply to this message
Old 09-27-2015, 03:54 PM   #2 (permalink)
you could of bent something tightening it like that.
also auto and manual motors have a diiferent bearing that normally gets stuck in the flywheel or rear crank.
Then did you bleed the clutch?
and new clutch need break in time or they will glaze and slip.
and try to put it in gear while the car is off
Old 09-27-2015, 04:02 PM   #3 (permalink)
if you had to force it on, odds are the input shaft could be bent, or the bearing could be toast. yank and inspect
slo_eg8 is online now   Reply With Quote Quick reply to this message
Old 09-27-2015, 04:09 PM   #4 (permalink)
yea i bleed the clutch and i shut the car off and put in second gear and moved the car back and fourth and the car went all the way back so the trans isnt workin in gear
Old 09-27-2015, 04:22 PM   #5 (permalink)
also the trans sat in the car for 2 years and was used when the motor/blockblew a hole threw it if this makesa difference
Old 09-27-2015, 05:19 PM   #6 (permalink)
Check axles.....
Also which bolts did you use to bolt the flywheel to the crankshaft.
Old 09-27-2015, 05:28 PM   #7 (permalink)
ok like a dumbass i just went outside and noticed there was fluid on the ground all the way out to the road. Now i guess i didnt and knowone else noticed it. but i walked up the road where i drove and theres trans fluid off and on the ground where i drove. I know thats why it quit shifting completely. But be4 when i left the driveway where i sat for a moment there was puddle weather it was there from be4 i left or when i cam back. COuld it be the transaxle seals?
Old 09-27-2015, 05:33 PM   #8 (permalink)
don't think lack of fluid would kill it. sure its trans fluid and not clutch?
Old 09-27-2015, 05:34 PM   #9 (permalink)
Not moving and leaking fluid.
Says that your axle pop out.
Re stab it in the trans and see of you can get it moving.
You can drive a manual trans bone dry for a while. So i doubt low fluid would effect it like that.
Old 09-27-2015, 05:37 PM   #10 (permalink)
popped axle will leave a puddle....likely twisted the tip of the axle.
Telltale sign is speedo works, but car doesn't move.
Old 09-27-2015, 05:37 PM   #11 (permalink)
sounds like the axles wernt seated all the way. dammit bone. always right again
Old 09-27-2015, 05:48 PM   #12 (permalink)
clutch is full and i pulled the trans fill hole bolt and the trans is empty
Old 09-27-2015, 05:52 PM   #13 (permalink)
so shove the axles back in and try again
Old 09-28-2015, 09:31 AM   #14 (permalink)
Whoshot's Avatar
Rep Power: 44 Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !
Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !
Yeah mine went down the street and then went no where after a turn, axles fell out.
When you seat them there is a noticeable give/pop as you slip past the spring. If you didnt push hard for a few seconds and almost give up, then give it that one good push to pop it in, then you didnt seat them.
They stop laughing at your piece of shit when they can only see it through your dust.
R.I.P. - NN4S
R.I.P. - Cali Noob
You guys are gone but never forgotten, we live each day to the fullest for you, who cannot see the new day we often forget is amazing.
xbox gamer tag: angeloah
Whoshot is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 04:47 PM. | Welcome to Forum, please register to access all of our features.
