95 civic b7 si swap need info - D-series.org
Old 07-31-2010, 03:14 AM   #1 (permalink)
cdaley98's Avatar
Rep Power: 0 cdaley98 is trying to make new friends
Default 95 civic b7 si swap need info
Hey guys I'm doing the si tranny swap just woundering what type of gear oil I should be using in the tranny?
cdaley98 is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 06:33 AM   #2 (permalink)
Rep Power: 14 hatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatnesshatchaddict is approaching greatness
iTrader Score: 31 reviews
honda mtf. i personally use GM syncromesh
hatchaddict is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 06:37 AM   #3 (permalink)
Im Bringing TSEXY Back!
T-MacK's Avatar
Rep Power: 32 T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !
T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !
Either one works fine!
Enjoy the tranny and the clutch by the way.
Hella Flush.....Were waiting!
Xbox gamer tag: THErealTMACK
T-MacK is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 07:48 AM   #4 (permalink)
fuck honda mtf
they changed their formula to a thinner weight, Bone remarked on this before
do what I did in my last manual, mobile 5000 5w30 regular
Old 07-31-2010, 07:50 AM   #5 (permalink)
00_civic757's Avatar
Rep Power: 11 00_civic757 will become famous soon enough00_civic757 will become famous soon enough00_civic757 will become famous soon enough
GM syncromesh
00 ek y7 coupe - dog shit slow....TRADED
90 da b17 block/b16head coupe - quick when i had it but fast as shit now that my boy has done a few things to it....TRADED
95 eg z6 4 door - slow but decent for a Z6....TRADED
90 ef LS hatch- fast little fucker....it was a street legal go cart that BALLED lol...TRADED
97 ek GSR coupe - 8500 RPM is way way better than 7200rpm in LS EF....GOT A ROD KNOCK
00_civic757 is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 07:54 AM   #6 (permalink)
10w30 motor oil as stated in the owners manual.
Mobil 5000 or Supertech....which are the same thing basically.
Old 07-31-2010, 11:09 AM   #7 (permalink)
Rep Power: 10 Z6hatch is nobody
I am using mobil 5000 10 30. I got 2 cases of clean 5000. For 41 bucks. Enough for several oil changes and the new trans y8 I'm installing
04 civic si EP3 k20a3 TRADED LIKE CANNED GOODS
00 Honda CRV B20Z
06 Civic SI (GF's car)
91 Crx SI TGP
94 Accord DX Coupe H22 w/ LSD
96 Prelude VTEC NBP
Z6hatch is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 11:13 AM   #8 (permalink)
Certified O.G.
Staypuff578's Avatar
Rep Power: 27 Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !
Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !
iTrader Score: 58 reviews
Send a message via AIM to Staypuff578
If you go synchromesh make sure to get the one that states it has the friction modifiers. I made the mistake of getting the one without and well....i'm on my second tranny.
Staypuff's ECU/Wiring services- PM me for OBD0/OBD1 ECU Chipping/Conversions, and all ECU Jumpers.
almost as badass as my mustache, like a mustache with tits
Instagram- Spoolin_Larry
Staypuff578 is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 11:19 AM   #9 (permalink)
Honda mtf is like water. Way too thin
00 Honda CRV B20Z
91 Crx SI TGP
96 Prelude VTEC NBP
Old 07-31-2010, 01:45 PM   #10 (permalink)
O'Reiley's
Old 08-02-2010, 06:04 AM   #11 (permalink)
cdaley98's Avatar
ok so i got the trans all hooked up and the car moving but im noticing when i drive it hard the 3rd gear grinds. Any solutions for this?
iconAll times are GMT -8. The time now is 01:54 AM. | Welcome to Forum, please register to access all of our features.
