91 Civic Driver Side Axle Seal - D-series.org
Old 05-26-2010, 12:02 AM   #1 (permalink)
Rep Power: 0 mrhongkongwong is nobody
Default 91 Civic Driver Side Axle Seal
I tried to replace my axle seal tonight and I ordered part # 91205-PL3-B01, the I.D. is larger then what I took out. Does anyone have the correct part #? It's a 1991 Civic Si with the standard D16 in it.
mrhongkongwong is offline   Reply With Quote Quick reply to this message
Old 05-26-2010, 12:08 AM   #2 (permalink)
RhapsodynMotion's Avatar
Rep Power: 13 RhapsodynMotion is starting to learn the ropesRhapsodynMotion is starting to learn the ropesRhapsodynMotion is starting to learn the ropesRhapsodynMotion is starting to learn the ropesRhapsodynMotion is starting to learn the ropesRhapsodynMotion is starting to learn the ropesRhapsodynMotion is starting to learn the ropes
which side are you doing it on?
RhapsodynMotion is offline   Reply With Quote Quick reply to this message
Old 05-26-2010, 12:10 AM   #3 (permalink)
Driver Side.
Old 05-26-2010, 12:13 AM   #4 (permalink)
Auto parts store: Honda Parts Unlimited
Old 05-26-2010, 12:14 AM   #5 (permalink)
DemoFly's Avatar
Rep Power: 12 DemoFly is a name known to allDemoFly is a name known to allDemoFly is a name known to allDemoFly is a name known to allDemoFly is a name known to allDemoFly is a name known to allDemoFly is a name known to allDemoFly is a name known to allDemoFly is a name known to allDemoFly is a name known to all
RockAuto Parts Catalog
Doesn't show or list driver side...wtf, that's part of the housing?
YOU DON'T HAVE TO POST
I hate cars, but I love engines.
DemoFly is offline   Reply With Quote Quick reply to this message
Old 05-26-2010, 04:19 AM   #6 (permalink)
90-91 Si Honda parts database is messed up, order a seal for 92-95 drivers side.
Should be 91205-PL3-A01
B01 is for Wagon RTAWD and B series, 90-93.
Old 05-26-2010, 08:01 AM   #7 (permalink)
sweet, the measurements seem to match up perfectly.
Is 91206-PL3-A01 the correct seal for the passenger side?
Old 05-26-2010, 01:16 PM   #8 (permalink)
correct
Old 05-26-2010, 07:54 PM   #9 (permalink)
Rep Power: 0 Lotowork is nobody
Heres what I do anytime i take out a cv,,,,Go to your local bearing supply house, bring the seal in with you and they sell you a new one for 3-4$ make sure to get a seal with both the axial, and radial wiper. (as a conventional seal usually has just a radial wiper)
usually the bearing supply house seal will be a little thinner...eg 6mm wide,,, vrs your stock seal at 8mm wide. This is not a problem, just be sure the face of the seal is flush with the cast boss on your transmission- when installing (I hand start make sure its square, then drive flush with a 2x2x1" thick block of wood), clean and apply oil to seal faces.......and your done.
Lotowork is offline   Reply With Quote Quick reply to this message
Old 05-27-2010, 08:13 AM   #10 (permalink)
D-Series Destruction Master
f00ker's Avatar
Rep Power: 36 f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !
f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !
iTrader Score: 31 reviews
Send a message via AIM to f00ker Send a message via MSN to f00ker Send a message via Yahoo to f00ker
Heres what I do anytime i take out a cv,,,,Go to your local dealership and get the correct part the first time, all the time.
1996 Subaru Legacy L
1998 Ford Explorer XLT
f00ker is offline   Reply With Quote Quick reply to this message
Old 05-27-2010, 01:03 PM   #11 (permalink)
But how can you get the correct part if the parts database is wrong????
Old 05-27-2010, 02:40 PM   #12 (permalink)
Rep Power: 0 weaverofthemind is trying to make new friends
part number 91205-PL3-B01 for left and 91206-PL3-A01 for right side.
found these parts numbers on World Pac, the company i work for orders parts through them for OEM replacements so they should be good numbers.
I'm so jdm i mix shell v-power and chevron techron together so i can have vtec gas.
Kick it in for a full tank.
weaverofthemind is offline   Reply With Quote Quick reply to this message
Old 05-27-2010, 04:06 PM   #13 (permalink)
f00ker's Avatar
Didn't have a problem last time I did this.
Old 05-27-2010, 04:43 PM   #14 (permalink)
bones right, 5th gen dx axle seals.
had this very same issue on my second tranny swap on my 90 dx 4dr
pain in the nutsack
Old 05-27-2010, 07:20 PM   #15 (permalink)
91205-PL3-B01 is wrong number, they are just copying Honda's fuckup.
Old 05-27-2010, 07:36 PM   #16 (permalink)
bone, you should throw that info into one of your many tranny threads for sticky powah.
the honda dealership parts guy was flabbergasted that *GASP* hondas part numbers were wrong!!!
lol
Old 05-27-2010, 07:38 PM   #17 (permalink)
lol
I'll bet it is already in a sticky somewhere.....what we need, moar stickys
Old 05-27-2010, 07:40 PM   #18 (permalink)
moar transzex stickys
fixed
iconAll times are GMT -8. The time now is 08:56 PM. | Welcome to Forum, please register to access all of our features.
