4 speed & 5 speed - D-series.org
Old 05-17-2010, 05:55 PM   #1 (permalink)
leemo559's Avatar
Rep Power: 16 leemo559 is hot as a volcanoleemo559 is hot as a volcano
leemo559 is hot as a volcanoleemo559 is hot as a volcanoleemo559 is hot as a volcanoleemo559 is hot as a volcanoleemo559 is hot as a volcanoleemo559 is hot as a volcanoleemo559 is hot as a volcanoleemo559 is hot as a volcanoleemo559 is hot as a volcanoleemo559 is hot as a volcanoleemo559 is hot as a volcano
Question 4 speed & 5 speed
jus wants some input about the setup im putting together...i have an 89 crx hf...wit a 4 speed mt....im goin to convert my car to obd 1 n a few upgrades to my b7....should i keep the 4 speed or upgrade to a 5 speed will there b much differance...
dreams do come true leemo. You just have to work for it and give it some time. Unless you're big ballin, then you can do anything right away
leemo559 is offline   Reply With Quote Quick reply to this message
Old 05-17-2010, 06:26 PM   #2 (permalink)
Go with a 5 speed SI trans, you will love the difference.
[email protected]
Old 05-17-2010, 08:42 PM   #3 (permalink)
SeeAhrX's Avatar
Rep Power: 0 SeeAhrX is nobody
YES! get an Si trans or have one pieced together.
makes a HUGE difference in acceleration.
SeeAhrX is offline   Reply With Quote Quick reply to this message
Old 05-18-2010, 04:55 AM   #4 (permalink)
They call me Awesome!
awebb's Avatar
Rep Power: 38 awebb is on a level you can only DREAM about! ! !awebb is on a level you can only DREAM about! ! !
awebb is on a level you can only DREAM about! ! !awebb is on a level you can only DREAM about! ! !awebb is on a level you can only DREAM about! ! !awebb is on a level you can only DREAM about! ! !awebb is on a level you can only DREAM about! ! !awebb is on a level you can only DREAM about! ! !awebb is on a level you can only DREAM about! ! !
iTrader Score: 15 reviews
Si gear box! If you can't find one of those grab a 5spd from a DX, the gearing ratio is the exact same, the only difference is the final drive gearing ratio.
2 Corinthians 5:7, We live by Faith, not by sight.
Have you checked
today?
Don't get your feelings hurt over some idiot's personal opinion, especially MINE!!!
awebb is offline   Reply With Quote Quick reply to this message
Old 05-18-2010, 06:19 AM   #5 (permalink)
boostfreak0885's Avatar
Rep Power: 20 boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
Send a message via AIM to boostfreak0885
2nd and third gear are different between the B000 case and A000..
si second is 1.9
si third is 1.25
dx second is 1.761
dx third is 1.172
about 9mph difference in second gear alone
my new and improved build... check it out
best time so far
11.201 at 128mph with a 1.79 60 foot.. damn i need traction, best trap speed is 129mph. 26psi h1c
NEW best 60' 1.56!!!
boostfreak0885 is offline   Reply With Quote Quick reply to this message
Old 05-18-2010, 06:58 AM   #6 (permalink)
awebb's Avatar
Originally Posted by Gearing ratio
88-91 Civic/CRX DX/LX:
1st Gear 3.250
2nd Gear 1.894
3rd Gear 1.259
4th Gear 0.937
5th Gear 0.771
Reverse 3.153
Final Drive 3.888
88-91 Civic/CRX Si:
1st Gear 3.250
2nd Gear 1.894
3rd Gear 1.259
4th Gear 0.937
5th Gear 0.771
Reverse 3.153
Final Drive 4.250
Source
Have you checked
today?
Old 05-18-2010, 08:01 PM   #7 (permalink)
leemo559's Avatar
good info thanks
Old 05-18-2010, 08:09 PM   #8 (permalink)
Originally Posted by webba1 View Post
92-00 dx and si/ex is what i was comparing.
best time so far
Old 05-18-2010, 10:16 PM   #9 (permalink)
why????
He has a cable car.......
iconAll times are GMT -8. The time now is 08:55 PM. | Welcome to Forum, please register to access all of our features.
