95 Civic 4-door sedan replacement steering column too short? - D-series.org
Old 05-26-2018, 03:43 PM   #1 (permalink)
Rep Power: 0 ryanman0 is trying to make new friends
Default 95 Civic 4-door sedan replacement steering column too short?
Hello, I am looking for some assistance in finding the correct length shaft for my vehicle.
I bought a new replacement steering column part from ebay which was listed as #53200-SR3-A02. However, it is too short. I have attached pictures. When I line up the mounting points and the steering wheel side, you can see how much shorter the shaft length.
When I check hondapartsnow, I only see 2 columns listed. One lists Mfg. Origin: USA and doesn't state "tilt". The other one list Mf. Origin: JPN and lists tilt. However, 53200-SR0-A02 lists "replaced by: and tilt 53200-SR3-A02. So I was assuming they were both interchangeable. I checked auto tranny, DX, LX, and they all list the same part numbers.
https://www.hondapartsnow.com/parts-...ng-column.html
Does anyone know what part number is longer or if I just got the wrong part delivered? Is there a way to get the exact measurements for each part numbers so I can compare.
My vehicle is a 1995 Civic, 4 door sedan, 5speed manual, tilt steering, power steering. Let me know if this is not the correct forum for this topic.
Thank you in advance,
Ryanman
ID:	124731   Click image for larger version
ID:	124733   Click image for larger version
ID:	124735   Click image for larger version
ID:	124737   Click image for larger version
ryanman0 is offline   Reply With Quote Quick reply to this message
Old 05-26-2018, 05:10 PM   #2 (permalink)
Pull on the shaft, the collapsible column, is collapsed.
Old 05-31-2018, 08:41 AM   #3 (permalink)
Thanks Bone! I pulled really hard and it finally expanded (popped completely off). I put it back on, adjusted it to the correct length, and installed it. You saved me again! Thanks so much.
Tags
steering column civic dx
iconAll times are GMT -8. The time now is 06:35 AM. | Welcome to Forum, please register to access all of our features.
