98 EK manual rack conversion - D-series.org
Old 03-14-2017, 07:08 AM   #1 (permalink)
awescott87's Avatar
Rep Power: 0 awescott87 is nobody
Default 98 EK manual rack conversion
Hey Everyone,
Ive watched this forum for a little bit but this is my first post.
I recently purchased a 98 ek with a d16y7. The power steering steering rack is worn out and i would like to replace with a manual one. From everything i have read on the ek you dont need to swap the sub frame or anything its just a simple rack swap besides the u joint but can't find any info on what size joint to get.
Does anyone have any experience with this and know what size u joint to get?
Thanks
awescott87 is offline   Reply With Quote Quick reply to this message
Old 03-14-2017, 12:39 PM   #2 (permalink)
manual rack? get an 92-95 u-joint. if its the same sized spline on the rack side. if not, you should be able to retain your u-joint.
https://www.d-series.org/forums/want-...nt-wanted.html
Old 03-14-2017, 01:39 PM   #3 (permalink)
I have a power subframe in my EF, and the trick to using a manual rack was to double the bushings on the non pinion side of the rack. Put the manual rack bushing on the rack, then put the PS rack bushing over that, and then bolt it all up.
Like batman said you need a U joint to hook the manual rack up to the OEM steering column. OEM one doesnt work, IIRC its too big. The proper sized piece of aluminum could be used as a bushing, perhaps.
Old 04-09-2017, 10:15 PM   #4 (permalink)
Rep Power: 3 RebornFromAshes is nobody
I been thinking about converting my steering rack as well on my 98 civic. Did you find out the size of the joint?
RebornFromAshes is offline   Reply With Quote Quick reply to this message
Old 04-10-2017, 06:48 PM   #5 (permalink)
so, did you like, not read the link I posted?
Old 04-10-2017, 07:30 PM   #6 (permalink)
Retired From Hondas
Esotericimage's Avatar
Rep Power: 37 Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !
Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !
I didnt know EK's came with a D16y7
Thot they were all B16B's
http://www.hondatuningmagazine.com/t...ode_checklist/
DSO Spam Basher
Originally Posted by Artikgrau325is
People try so hard to be unique, they lose their sense of style
Esotericimage is offline   Reply With Quote Quick reply to this message
Old 04-11-2017, 06:22 AM   #7 (permalink)
Rep Power: 7 Animag771 will become famous soon enoughAnimag771 will become famous soon enoughAnimag771 will become famous soon enough
Slo - Just read that thread you posted. I've been tempted to turn my 94 Del Sol into manual steering. I may never end up doing it, I'll have to loop the lines and take the belt of to see how it feels. Based on the first post on that thread it seems like it my power U-Joint should work. It might not take much to make the swap on mine... Or would it?
OP - just curious what your reasoning for wanting to swap to manual steering is?
Animag771 is offline   Reply With Quote Quick reply to this message
Old 04-11-2017, 06:47 PM   #8 (permalink)
taking the belt off isn't that great. Ive ran mine like that for awhile, pain when stopped, but rolling, you cant tell the difference.
Old 04-12-2017, 05:12 AM   #9 (permalink)
Did you loop your lines as well? I've been told it makes a difference, because the fluid isn't "fighting the pump". Not sure how much truth there is to it, but it's worth trying.
Old 04-12-2017, 05:24 AM   #10 (permalink)
endo_bobo
sir_bobos's Avatar
Rep Power: 38 sir_bobos is on a level you can only DREAM about! ! !sir_bobos is on a level you can only DREAM about! ! !sir_bobos is on a level you can only DREAM about! ! !
Send a message via MSN to sir_bobos
Looping the lines isn't the same as a real manual rack. And keeping the P/S isn't that big of a detriment nowadays. This ain't your granddaddy's Buick.
I play Black Metal, I don't need to know chords.
A09/TQ2.0.02155F1 CIV
sir_bobos is offline   Reply With Quote Quick reply to this message
Old 04-12-2017, 06:30 AM   #11 (permalink)
I know it isn't the same as a manual rack, its just a shortcut to get similar results. Not quite as effective though as converting to a real manual rack. And you're definitely right, it's not your grandaddy's Buick, but cars are so light they really don't need power steering though it is definitely nice at very slow speeds.
Old 04-12-2017, 05:57 PM   #12 (permalink)
nope. the thing leaked anyways, so I just ran it without the belt and whatever was in the lines/rack.
Old 04-14-2017, 01:39 AM   #13 (permalink)
Retired From Hondas
I did'nt loop my lines, I just took them off. opened it up..packed it with grease, then just let the air transfer in and out as needed.
DSO Spam Basher
Old 04-15-2017, 10:45 AM   #14 (permalink)
The quickest and easiest thing to do is cut the pressure line, pull out the inner metal spiral, and then just route it back to the return nipple and secure with a hose clamp. Looped in 10 mins.
For what its worth my old 98 CX race car had a manual rack from the factory. (so maybe look up what u joint a CX uses and order that)
Old 05-20-2017, 10:19 AM   #15 (permalink)
Mr.Fodo's Avatar
Rep Power: 14 Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!
Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!
Looping will leave play in the power rack de-powered, check out the DIY section.
The integra/ek/(maybe)del sol racks will have slightly less than the EG style ones.
For street cars it may not be a big deal for you. But performance driving, that slop is annoying. The grippier your tires, the more you notice.
Start there, if you still cant figure it out, you are not going to.
How
to act on this forum...
Mr.Fodo is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 07:42 PM. | Welcome to Forum, please register to access all of our features.
