95 del sol cant figure out what the wheel rattle is exactly - D-series.org
Old 11-03-2016, 09:24 AM   #1 (permalink)
Rep Power: 0 colorsharpkid is nobody
Default 95 del sol cant figure out what the wheel rattle is exactly
95 del sol sir
someone swapped it from the b16a3 dohc
to a d15b7 sohc i have a standard and a s20 long gear tranny
the front rotors look 10.3in i have tone
hubs for the abs yes or whatever it is and they work ive tested the abs
so this car came with all abs and 4 disk brakes
i have inspected it a few times and this is my conclusion
the rotors themselves are not perfectly stationary they have a tiny bit of play allowing them to spin left and right a tiny fraction of a inch even tho the 4 lug nut bolts are thru it and the set screw thats not needed was being used to hold them in place better but it always and i mean always find its way out and recently just snapped the dumb set screw but we all know that screw is just to hold the rotor temp while adjusting the brake pad and most owner remove and discard that screw anyways
thats not the solution but was a good temp fix
any one have a any suggestions ?
should i just punk out get new rotors and hope they match up without wobble . but makes kinda no sense then the wobble is comming from what ? the rotors holes too big and slight play happens or is it the behind rotor the hub or somthing .... grrrrrr i read somthing about i may have mini cooper rotors on it or somthing weird but idk for sure i see write ups on conversions and stuff but i dont see anyone referring this wobble issue
colorsharpkid is offline   Reply With Quote Quick reply to this message
Old 11-03-2016, 09:26 AM   #2 (permalink)
Thumbs up
candy
Old 11-04-2016, 06:01 PM   #3 (permalink)
HondaDNA's Avatar
Rotors shouldn't move at all if you have the lug nuts torqued properly.
Old 11-04-2016, 06:06 PM   #4 (permalink)
could be wrong sized hubs, could be worn hubs,
Old 12-22-2016, 09:18 AM   #5 (permalink)
LTB
LTB's Avatar
Rep Power: 10 LTB is learning the way of the DLTB is learning the way of the D
Loose wheel bearings?
1994 DELSOL SMF
FVSCC.COM
CWSCC.COM
BEYONDREDLINE.COM
LTB is offline   Reply With Quote Quick reply to this message
Old 12-22-2016, 10:09 AM   #6 (permalink)
pictures, because your words are not working here.
Sounds like your rotor lug holes are biggere in diameter then your hub.
if thats the case then its moving around.
The rotor shouldnt have side to side play when the tire is tq down.
Old 12-22-2016, 05:42 PM   #7 (permalink)
Sailor's Avatar
As above, the rotors shouldn't move. Are you sure they're at fault or is it something inboard of them?
Four Hondas: two working
Tags
brake, del sol, rotor, wobble sound
iconAll times are GMT -8. The time now is 06:52 AM. | Welcome to Forum, please register to access all of our features.
