Stripped front lca bolt - D-series.org
Old 07-26-2015, 12:25 AM   #1 (permalink)
jcrew's Avatar
Rep Power: 8 jcrew is trying to make new friends
Default Stripped front lca bolt
Today i decided to pull out the front lca for my project car for bushing replacement.
I pulled out easily the left side but when im working on the right side and undoing the last two bolts the two adjacent bolts were very hard to undo i have managed to loosen it up to 1/4 the bolt only, so i decided to retighten it again and it is too hard also i have to use my foot, luckily one bolt tightened but the other one has been stripped
This bolt stripped
I wonder what remedt can i do with this, its the first time that happened to me. I wonder if one bolt will handle considering this will be my track car. Im also thinking to put a nut on it but i cant have an access inside i guess i have to cut out the body to do this option.. Has anyone experienced this? Help would be greatly appreciated. Thank you
jcrew is offline   Reply With Quote Quick reply to this message
Old 07-26-2015, 12:27 AM   #2 (permalink)
jcrew's Avatar
Sorry for the third picture
This bolt stripped
Old 07-26-2015, 05:34 AM   #3 (permalink)
Probably have to cjt a hole in the top and weld a new nut in place once you gotten the bolt out.
I never had that bolt strip out, but i had the inner lca bolt strip out. I had to cut a pocket and pop a nut in then use a wrench to hole the new nut while i tighten it all down.
Work and last
Old 07-26-2015, 06:53 AM   #4 (permalink)
jcrew's Avatar
Thanks mate, thats what in my mind now.. I wonder if i have gotten away with this if i have used an air impact wrench.. Cause when i loosen it with a breaker bar i tend to misalign the bolt when twisting it with full force.. Just thinking how can i avoid this the next time
Old 07-26-2015, 07:52 AM   #5 (permalink)
jpciii's Avatar
Rep Power: 13 jpciii is obviously a regularjpciii is obviously a regularjpciii is obviously a regularjpciii is obviously a regularjpciii is obviously a regularjpciii is obviously a regularjpciii is obviously a regularjpciii is obviously a regular
Yes, impact wrenches work better for this sort of thing.
jpciii is offline   Reply With Quote Quick reply to this message
Old 07-26-2015, 08:17 AM   #6 (permalink)
shoebox_civic's Avatar
I've never had those strip either, they're beefy bolts... Im not sure where youd even cut into to get to the other side
99 CRV
17 Q50 2.0T
07 350Z touring
Old 07-30-2015, 04:49 AM   #7 (permalink)
Iagreen's Avatar
Rep Power: 5 Iagreen is starting to learn the ropesIagreen is starting to learn the ropesIagreen is starting to learn the ropesIagreen is starting to learn the ropesIagreen is starting to learn the ropesIagreen is starting to learn the ropes
Loosening wont strip a bolt, maybe the head but not the threads. Be careful reinstalling with an impact as that can strip a bolt very fast if it starts crooked. I'd bet some dirt got on the threads when you were putting the bolt back in.
Iagreen is offline   Reply With Quote Quick reply to this message
Old 07-30-2015, 09:44 AM   #8 (permalink)
v8killaz's Avatar
Rep Power: 12 v8killaz is almost there....
v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....
ohh really
most epic thread-
v8killaz is offline   Reply With Quote Quick reply to this message
Old 08-25-2015, 03:51 PM   #9 (permalink)
Rep Power: 0 jryKC is trying to make new friends
Work and last
I've had to do the same thing for some front sway bar bracket bolts.
jryKC is offline   Reply With Quote Quick reply to this message
Old 08-25-2015, 06:02 PM   #10 (permalink)
Michael99's Avatar
Rep Power: 8 Michael99 is learning the way of the DMichael99 is learning the way of the D
I also striped font sway bar bolt and and I upgrade all 4 to m10 x1.25 I believe.
and I also mentioned if you put a lot of oil on the area of where you planing to disassemble, week or more before it will help a lot. When I relapsed my rear drums to disk - on one side i got shock leak and all arms was in oil and all bolts on that side I loosened easy. On another side I brake like 3 bolts!
Michael99 is offline   Reply With Quote Quick reply to this message
Old 08-27-2015, 11:28 PM   #11 (permalink)
satansbrother's Avatar
Rep Power: 8 satansbrother is learning the way of the Dsatansbrother is learning the way of the D
If a bolt has alot of corrosion on an open end and you try to back it out, there is a good chance you will pull the threads (strip the hole) but usually that only happens with softer materials
satansbrother is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 12:44 PM. | Welcome to Forum, please register to access all of our features.
