2004 EM2 Civic Energy bushings problem - D-series.org
Old 07-10-2015, 03:23 PM   #1 (permalink)
Rep Power: 0 fordover is nobody
Default 2004 EM2 Civic Energy bushings problem
Hi Everyone,
As the title explains, I've run into a wall re-assembling the front end. The control arms with the new bushings are installed but I can't get the ball joint back into place. Currently, the knuckle is loosely bolted (both bolts) onto the strut and the sway bar end link is disconnected. Those bushings are incredibly stiff so I can't push the the control arm down enough to clear the 2 inches required to slip the ball joint in.
Can anybody with experience chime in on how it's done?
Thanks in advance.
fordover is offline   Reply With Quote Quick reply to this message
Old 07-11-2015, 06:05 PM   #2 (permalink)
Never mind, figured it out.
Old 07-11-2015, 06:51 PM   #3 (permalink)
and what did you do different?
Old 07-11-2015, 07:07 PM   #4 (permalink)
HondaDNA's Avatar
Use a breaker bar to push it down, or have a "fatter" friend step on it
Old 07-11-2015, 09:22 PM   #5 (permalink)
I tried that and I bent 2 pry bars to no avail. Conventional wisdom tells you to bolt the knuckle in and then slip the joint into the control arm. Unfortunately, this only works with OEM rubber bushings as they have more play than poly bushings. Instead:
1) I put the ball joint in first.
2) Wiggled the CV shaft into the knuckle while slightly prying down between the control arm and the subframe (unless you have 3 arms have someone help you). Be mindful of the ABS sensor.
3) Slipped the bottom bolt of the knuckle to the strut (if it isn't aligned quite right push down on the pry bar from step 2 to help it get into place).
4) Finally, pushed (a bit of effort) the top of the knuckle to align the top bolt to the strut.
For some reason I don't understand, the driver side shaft (longer CV shaft) was tougher to wiggle it into the knuckle but it can be done. The sway bar end links MUST be disconnected or this will never work.
Edit: One last note; the biggest pry bar you can insert into the wheel well is a 24 incher in my experience. I had to use a section of an exhaust mid pipe to get more leverage on the pry bar.
Old 07-12-2015, 09:15 AM   #6 (permalink)
shoebox_civic's Avatar
Use a bottle Jack to raise the lca up to the ballpoint :tu:
99 CRV
17 Q50 2.0T
07 350Z touring
Old 07-12-2015, 04:15 PM   #7 (permalink)
The lca needs to be lowered; raising it won't do anything.
Old 07-12-2015, 07:46 PM   #8 (permalink)
HondaDNA's Avatar
I forget I work on cars on a lift, and my breaker bar is 5 feet long and will move any control arm I pry on lol. Remember I said breaker bar not pry bar.
iconAll times are GMT -8. The time now is 12:26 PM. | Welcome to Forum, please register to access all of our features.
