86-89 accord struts on 91 ED hatch - D-series.org
Old 05-18-2015, 06:50 PM   #1 (permalink)
mitchwbr's Avatar
Rep Power: 7 mitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regular
Default 86-89 accord struts on 91 ED hatch
Ok so current coilovers in the rear are insanely stiff (not really sure why but I think their just made that way.) Their tanabe sustec pros. Anyways dont care and dont really care about coilovers its my daily blah blah blah.
Plan is to purchase 86-89 accord tokico blues and stick em on the rear (fronts are kyb's and tein s tech and I like them a lot.)
Problem is I have s tech springs that were meant for A DA..... I had heard the DA struts are taller in the rear so thought came to mind to get the accord Tokico. But my question is will I still have that 1.5 or whatever it is drop if the combo is Accord tokico blues, Tein S tech's meant for A DA, all on A 91 civic?
I tried searching for how tall OEM civic springs are but I couldnt find anything. Guess I could go to the junkyard and compare that height with the tein's I have for the DA. The DA tein springs are 13'' tall exactly.
Not going for performance or super low here...... Just want to drop the daily
Stock D15b7, z6 head, Precision 5431, 450 inj.
Vtak turned off. 220 hp 175 tq.
mitchwbr is offline   Reply With Quote Quick reply to this message
Old 05-18-2015, 08:17 PM   #2 (permalink)
unsprung spring height wont tell you a damn bit of information. there are lowering springs out there that are 4inches shorter than factory unsprung, yet only a 1" drop.
No idea on the strut question. OEM struts are good quality, and you can get strut topmounts that allow the strut rod to come up a couple inches more so you dont blast it rightaway with lowered car height
Old 05-19-2015, 07:31 AM   #3 (permalink)
Tape-R taper/driver
LowFlyin''s Avatar
Rep Power: 17 LowFlyin' is the fucking MAN!!!!LowFlyin' is the fucking MAN!!!!LowFlyin' is the fucking MAN!!!!
LowFlyin' is the fucking MAN!!!!LowFlyin' is the fucking MAN!!!!LowFlyin' is the fucking MAN!!!!LowFlyin' is the fucking MAN!!!!LowFlyin' is the fucking MAN!!!!LowFlyin' is the fucking MAN!!!!LowFlyin' is the fucking MAN!!!!
Sweet, so you guys did the McPherson conversions on your cars?
-Chris
'87 Civic Si
'91 CRX SiR
'91 Civic Tape-R
'91 Civic Wagon RT4WD
'03 Astro AWD
LowFlyin' is offline   Reply With Quote Quick reply to this message
Old 05-19-2015, 02:14 PM   #4 (permalink)
mitchwbr's Avatar
OK uninstalled height won't matter got ya. Damn I guess I'm in a bind then......
Old 05-21-2015, 04:53 PM   #5 (permalink)
mitchwbr's Avatar
Bump nobody knows if DA springs are taller?
Old 05-23-2015, 09:40 AM   #6 (permalink)
DA springs are a bit taller. I used DA springs on the Wagon to raise it a little.
I also ran the 89 Accord struts back in the day. I only ran the front ones, and used a Civic top hat. Let the car go a lot lower without bottoming out the shock.
iconAll times are GMT -8. The time now is 04:29 AM. | Welcome to Forum, please register to access all of our features.
