7 wire hx to 4 wire o2 - D-series.org
Go Back   D-series.org Everything Else New Member Introductions
Old 01-30-2015, 09:34 AM   #1 (permalink)
Rep Power: 0 ahardy25 won't last long at this rate
Default 7 wire hx to 4 wire o2
can i depin my primary and use the secondary o2 clip and pin in the 4 wires needed and plug and play my secondary 4 wire to make it a primary
ahardy25 is offline   Reply With Quote Quick reply to this message
Old 01-30-2015, 10:20 AM   #2 (permalink)
2jzdreamin's Avatar
iTrader Score: 49 reviews
So you want to use the 2nd O2 sensor as your primary o2 sensor but your primary O2 is 7 wires and you want to swap the plugs to make it work?
What year is the chassis and what ecu? All so can you post pics of both plugs for the O2 sensors?
all so do vtec sub-harness
instagram @magicman9won4
Old 01-30-2015, 04:36 PM   #3 (permalink)
yea and 2000 civic hx obd2a running a chipped p28
Old 01-30-2015, 06:43 PM   #4 (permalink)
HondaDNA's Avatar
You are better off getting a new 4 wire o2, that way you have no issues with fuel mileage. Unless the secondary o2 is fairly new?
Old 01-30-2015, 07:04 PM   #5 (permalink)
Pull up a ecu p8n out of the 2 ecu and compare the wires.
There was a write up on this.
The best thing to do is to cut your 2nd o2 harness off and tape up the cut wires.
Then find out which ecu pins are different on the hx and wire it in.
Or to make it easier just add all new wires for the 4 wire o2 to the ecu jumper harness. Less hacking on the oem harness.
Old 01-30-2015, 07:20 PM   #6 (permalink)
Now do work. I gave you a big bite of the pie.
Obd1 pin out
HTML code is On
iconAll times are GMT -8. The time now is 09:20 PM. | Welcome to Forum, please register to access all of our features.
