D17A2 into 1993 Civic - wiring question - D-series.org
Old 10-05-2011, 01:44 PM   #1 (permalink)
Rep Power: 0 HiredGun is nobody
Default D17A2 into 1993 Civic - wiring question
I thought with so many engine swaps being done that I could find more info.... I kneel before you begging for help. We swapped this motor in because it was basically free and seemed simple at the start.
We have the D17 installed with the ECU plugged in to the motor harness. I have the connector from the dash harness. Then of course we have the original chassis wiring harness. I have seen threads talking about mating harnesses together, but no specifics.
I am hoping to find info so I can send the ECU the signals it needs. Is that info availible? Then if I had the chassis wiring harness pinout I could just run the wires. Do I need to go to the dealer for wiring diagrams or has this process been simplified?
HiredGun is offline   Reply With Quote Quick reply to this message
Old 10-05-2011, 02:44 PM   #2 (permalink)
ive never heard of anyone putting an 01+ ECU in an older car, but hey why not?
Old 10-05-2011, 02:50 PM   #3 (permalink)
2jzdreamin's Avatar
iTrader Score: 49 reviews
can you post pics of the harness that connects to ecu?
all so do vtec sub-harness
instagram @magicman9won4
Old 10-05-2011, 03:34 PM   #4 (permalink)
might work better if you swap the gauge cluster as well.
or see if the earlier vss's swap over and the d17 ecu will recognize it
Old 10-05-2011, 04:23 PM   #5 (permalink)
I do have the gauges...
Here are some picts of the ECU and the chassis wiring.
ID:	29097   Click image for larger version
ID:	29098   Click image for larger version
Old 10-05-2011, 04:51 PM   #6 (permalink)
Rep Power: 9 v4lu3s is a name known to allv4lu3s is a name known to allv4lu3s is a name known to allv4lu3s is a name known to allv4lu3s is a name known to allv4lu3s is a name known to allv4lu3s is a name known to allv4lu3s is a name known to allv4lu3s is a name known to allv4lu3s is a name known to all
if i was to do that i would be sitting down with the d17 wiring diagram and the civic chassis wiring diagram. trace a lot of pinouts, put the d17 cluster in as well, and basically do a lot of splicing and experimenting. the closest thing i have done to this was put a 1991 civic ex auto drivetrain into a 1978 civic wagon and use the 78 harness AND the 91 engine/chassis harness and built custom tie ins for it all to run, it took a few weeks but when it was done it could pass emissions as a 1991 civic.
v4lu3s is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 06:32 AM   #7 (permalink)
the425th's Avatar
Rep Power: 10 the425th is fly like an eaglethe425th is fly like an eaglethe425th is fly like an eaglethe425th is fly like an eaglethe425th is fly like an eaglethe425th is fly like an eaglethe425th is fly like an eaglethe425th is fly like an eaglethe425th is fly like an eaglethe425th is fly like an eaglethe425th is fly like an eagle
Good luck
RIP Pat Primmer
XBL Gamertag: the425th
do i drive with my turbo on or no?
the425th is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 06:54 AM   #8 (permalink)
turboprelude95's Avatar
Rep Power: 27 turboprelude95 Still a JDM Star....
turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....
Easy solution, find free y7 or y8 with s spun bearing and swap d17 internals into it. Then there is no wiring to worrie about!
Crx
Jswap 4dr
Boost 4dr
Twin scrol
F2B
turboprelude95 is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 09:20 AM   #9 (permalink)
Speedjunky01's Avatar
Rep Power: 18 Speedjunky01 is a Top Aussie
Speedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top Aussie
iTrader Score: 40 reviews
a trend has begun!
resident verbal assault tech Jr.
240,000 miles and counting turbo EH9
nothing like 4drs, ac,moon roof, and 4 whores and running 13psi out or a ching chong t3/t4 setup
the build
if it survives the winter JdM d15b+Vitara+FJT+25psi=
professional tranny assassin, 2 stock diffs in 4 weeks on street tires and preload was used
Speedjunky01 is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 11:32 AM   #10 (permalink)
Where is the best place to get wiring harness information?
I guess I should have just found another D15 beater engine to throw in...
Old 10-06-2011, 11:47 AM   #11 (permalink)
the factory service manual is a great place to start.
Old 10-06-2011, 11:53 AM   #12 (permalink)
2jzdreamin's Avatar
do you know what the wires are for in that big flat gray plug in the first pic you posted?
Old 10-06-2011, 03:48 PM   #13 (permalink)
BLACK-KNIGHT's Avatar
Rep Power: 13 BLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropes
iTrader Score: 30 reviews
just swap a p28 ecu in it and be done
BLACK-KNIGHT is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 03:52 PM   #14 (permalink)
p28 will not run it correctly. the fuel and igition maps are pretty different, one factor being the different RTSR.
different quench, different sensors.
oh by the way creakin coil on plug ignitions!!
Old 10-16-2011, 12:27 PM   #15 (permalink)
that is the connection from the ecu to the chassis. I went to the dealer with that harness in hand. They could not help. hopfully a printout i got for the ecu matches that. at least I got a start...
Old 10-16-2011, 04:20 PM   #16 (permalink)
without the factory wiring diagrams you have a steep hill to climb.
iconAll times are GMT -8. The time now is 02:17 AM. | Welcome to Forum, please register to access all of our features.
