P28 - D-series.org
Old 04-30-2019, 08:29 AM   #1 (permalink)
Dserieslife's Avatar
Rep Power: 0 Dserieslife has been punished by the users of d-series.org
Default P28
Hey guys would it be worth buying a chipped and tuned p28 ecu for my stock 98 ex with d16y8?
Dserieslife is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 09:41 AM   #2 (permalink)
Old 04-30-2019, 10:23 AM   #3 (permalink)
Ok then lol
Old 04-30-2019, 10:58 AM   #4 (permalink)
Never finishes (TWSS)
Evanguy's Avatar
Rep Power: 18 Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
If you converted your car to obd1 getting ready to build a motor down the road you could load a.stock y8 map on your p28 and run it until you change something that requires a tune.
A tune on a stock motor isn't worth the money unless.you can do it your self or have a buddy with access to a dyno.
Old 04-30-2019, 03:52 PM   #5 (permalink)
tuning the stock motor does open up a little horsepower, but not recommended if that is going to be the most you do.
It is a great starting point for future use down the road, such as nitrous, NA build, or turbo, as with a stock motor, you do not have a butt ton of variables different from everyone else and it is easier to learn.
Tuning the stock setup does enable you to swap to modern fuel injectors, which in themselves, increases power and fuel efficiency due to a better fuel spray pattern/mist.
Id do it for a learning exercise that can bring a lot of future use.
If purely for power, well, you already got told lol
Old 04-30-2019, 07:30 PM   #6 (permalink)
Thanks alot guys for the feed back. Planning on building my civic and I haven't built one before this will.be my first and just trying to figure out where to start and what to do. Right now just got a aem intake and exhaust. But saving up money to go from there got bout 300 saved so far
Old 05-04-2019, 11:55 PM   #7 (permalink)
10mm's Avatar
Rep Power: 0 10mm will become famous soon enough10mm will become famous soon enough10mm will become famous soon enough
I'm in the same boat. I want to get my car ready for a cheap turbo setup. Before I go buy an eBay turbo kit I want to get the ECU and fuel taken care of so I'm not messing with that right after I have turbo installed (except for of course doing the fuel tuning)
I'm also really interested in learning how to tune. I've been researching all the different softwares available and from what I've gathered so far crome is the thing people are using with chipped p28
Crome has problems though and I think one day I'm probably gonna go with AEM because they have their own software that is maintained better
Where you planning on buying the chipped p28 from?
So if you're interested in learning how to tune as well I'd say it's definitely worth it even on a stock engine. Even more so worth it if you plan on doing some basic things like cat delete, header, full exhaust, upgraded fuel pump and injectors
10mm is offline   Reply With Quote Quick reply to this message
Old 05-05-2019, 08:42 AM   #8 (permalink)
Not sure where gonna get one when I do was just looking around at them online. And mods to come are a bigger air intake, ss drag header with 2.5 in cat back and test pipe then go from there
Similar Threads
Thread Thread Starter Forum Replies Last Post
P28 tuned fuel pump wont prime Jeka Engine Management 18 07-25-2019 12:14 AM
Rpm don't work with p28 VI_Nation 7th Gen 1 01-09-2016 09:09 AM
Fried P28 Ecu??? Shep Forced Induction 11 09-06-2015 05:00 PM
P28 base map Extra ft not working on Crome faburisu Engine Management 19 08-02-2015 08:15 AM
P28 testing dbuc89 Engine Management 10 04-27-2015 03:48 PM
iconAll times are GMT -8. The time now is 10:05 PM. | Welcome to Forum, please register to access all of our features.
